Old 09-09-2009, 03:15 PM
foisyt foisyt is offline
Default frequent crash when editing
My lovely PT LE8 crashes regularly when I'm editing audio tracks with TCE or Autotune5. Only PT is affected, not the OS or other apps if running (Safari).
I haven't found much related info in the duc posts or the Apple support pages. I've moved 3rd party plug-ins from the plug-ins folder to rule out those as causes. (except for Autotune5) The plug-in's are all up to date versions and purported to be compatible with PTLE8 even if they were released before PTLE8 was released (??).
The Crash Report is consistent:
...Thread 38 Crashed:
0 com.digidesign.framework.DAE 0x04017c08 FWAudioCallback + 184530...
I'd like to decipher the Crash Report. It must contain useful info in finding the cause. Can anyone tell me how this can be done? Or, if this is a valid approach to solving the problem.
-foisyt
PT LE 8.0, 002r, owc 500gb ext FW drive
MacBookPro 15" 2.4ghz 4gb OS 10.5.6
Old 09-12-2009, 04:39 PM
Default Re: frequent crash when editing
Okay, it's a tough one. How about this: Is there a known problem with Autotune5 rtas in ProtoolsLE8 causing crashes? The Crash reports don't mention Autotune but Antares came out with the upgraded Evo before PTLE8 came out. No more attention to AT5 then?
-foisyt
Old 09-12-2009, 05:15 PM
The Dougfather The Dougfather is offline
Sounds like a good time to switch to melodyne then???
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Frequent crashes tobbenos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-11-2010 12:51 AM
Editing MIDI volume causes PT crash rnd Pro Tools TDM Systems (Mac) 1 10-25-2009 06:54 PM
CPU overload frequent brianf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-12-2006 08:39 PM
Static sound after stoping playback/Frequent crash briancometa Pro Tools TDM Systems (Mac) 1 10-17-2005 08:05 PM
Frequent PT 6.9.1 crashes jigilous Pro Tools TDM Systems (Mac) 2 10-13-2005 05:39 PM
