Old 07-21-2004, 08:21 AM
aaron t aaron t is offline
Default neo access error -after extensive use
i'm a fairly new LE user and have gotten about 100 gigs into my current project
without a hitch. now all of a sudden i'm getting a "neo access error" when i try and
record and it won't stop play after that. i understand the troubleshooting and setups with
reference to preferences, but can't understand why i would just now be having the problem.
if anyone can throw some ideas at me, i'd surely appreciate them.
using a new emac 1.25 GHz with a meg of ram. this computer is reserved for my protools
use only.
thanks
aaron
Old 07-21-2004, 03:48 PM
MoreMeintheMonitors MoreMeintheMonitors is offline
Default Re: neo access error -after extensive use
Follow the 'General Troubleshooting' post sticky at the top of this forum.
Specifically you need to trash preferences and databases.
Old 07-21-2004, 03:50 PM
DigiTechSupt's Avatar
It sounds like your permissions have gotten scrambled or one of your Digidesign Databases has become corrupt. I would trash the folders called Digidesign Databases found on the root of all mounted volumes. Then launch the Apple disk utility and select to repair disk permissions on your system drive. You will find repair disk permissions on the first aid tab of the utility.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Old 07-22-2004, 01:03 PM
thanks, we're rolling again. sure appreciate all the input.
aaron
Extensive 9092 errors after upgrading system. Akkatha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-16-2008 08:37 AM
Neo access error Loudigi Pro Tools TDM Systems (Mac) 0 09-26-2005 12:23 PM
NEO access error????please ariel keshet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2004 08:22 AM
Extensive Midi Editing Demandred 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-05-2004 09:20 AM
extensive test results of 24bit flying calf a/d converter coaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-15-2000 06:22 PM
