Old 01-02-2008, 05:34 PM
brian4411 brian4411 is offline
Default Bypassing mbox preamps
is there a way to bypass the preamps in the mbox and just use it as an interface to connect to the computer?
edit: i probably should've specified that i'm using the Mbox2 mini
Old 01-02-2008, 09:49 PM
NonSpecific NonSpecific is offline
Default Re: Bypassing mbox preamps
as long as the 48 volt switch isn't depressed the pre-amps shouldn't be activated.
Old 01-02-2008, 10:19 PM
The preamp is always activated, even if phantom is off. Unless the mini has a SPDIF input, you cannot bypass the preamps. Why do you want to do this? Maybe someone will have a better idea for you.
bypassing mbox 3 preamps Lonefse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-17-2011 05:21 PM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2007 09:55 AM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2007 07:52 AM
Bypassing MBox preamps - direct in Ian-H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-25-2006 05:16 AM
bypassing preamps on mbox Rod Elledge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-30-2004 07:59 PM
