#21
Re: SSL Duende Native is out now... :)
#22
After a quick test I've discovered that Duende does in fact have latency.
At 48K it measures 11 samples. By comparison, the Click plugin has 9. So if you're playing to a click you'll be behind by 2 samples. That's 1/24,000th of a second. I stand corrected. I should also report that latency is being correctly reported for all Duende plugs and ADC compensates perfectly. The birth of this latency side project came from someone's claim that Waves had an advantage due to lower latency. I believe this puts the lid on that issue. Isn't there a Waves plugin with over 3,000 samples of latency? |
#23
zero phase is the answer! Don't forget the 1000's of UAD plugins users (including myself) who use wrapped UAD plugins all day long with no issues. and SSL Duende hardware versions were also wrapped and had no issues with the wrapper. The wrapper does not add any latency. All SSL Duende Native plugs have zero latency except Drumstrip and VocalStrip which have in the region of 200 samples. Chris
#24
So does the wrapped plugs use more processing than non-wrapped? The last time I tried the wrapper it seems like even small EQs used a large amount of horsepower. After a few tries I just did not see where it was worth it.
Imac Pro 27" 10-core with a LG 4K for a second screen OS 10.14.4 Pro Tools 2019.6 UAD Apollo X8P With an extra 8 channel ADAT using a Focusrite Liquid Saffire 56 UAD Twin duo UAD TB3 Octo Satelite Focal Twin Be monitors samsung T5 and Gdrive |
#25
Chris
#26
So, what's your opnion on the X-Verb? Most interested in this one. I was waiting for the RTAS version of LX480, but its taking soooooo long!
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
#27
"At 48K it measures 11 samples" which illustrates that they are not "zero" but incredibly low nonetheless. |
#28
But yes, it's a GREAT sounding reverb. It could stand alone in your reverb folder and your mixes could still sound excellent and diverse. |
#29
I've done plenty of checking any you can have 2 identical tracks! one with SSL plugins (not drumstrip or vocalstrip as i said these 2 have some latency) and there's no phasing what so ever. and they will null 100% I'm checking it now with 3 ssl plugs on one track and none on the second track. Try it and see what you find. Chris
#30
So again, these sound BETTER than their Waves counterparts? In what way?
Tell SSL, let them know we need Duende Native AAX ! | Gemylon | AAX Plug-ins | 7 | 05-20-2013 03:40 AM |
Duende Native &PT 10.2 | tele27 | Pro Tools 10 | 3 | 10-04-2012 02:05 AM |
Duende Native issues | ntbad | Windows | 0 | 09-17-2011 07:01 AM |
Duende Native available today... | JSR | Pro Tools TDM Systems (Mac) | 3 | 02-16-2011 09:04 AM |
New Duende SSL Native | M2E | Pro Tools TDM Systems (Mac) | 2 | 09-06-2010 05:33 AM |
