How to reduce/eliminate breathings editing recorded voice?
Hello everybody
I need to eliminate breathings from audio recorded voices. And I do it one by one because I still haven't found the way to eliminate all of them with just one or two commands. Can you imagine how many times breath four or five people in half an hour? I'm exhausted! Thanks, Sotosu |
Re: How to reduce/eliminate breathings editing recorded voice?
I forgot to tell that I do it six times a week, six programs each.
Sorry for the dumb question.. but.. did you try using an expander/gate/strip silence?
check out de-breath from waves.
big time saver e
ihatetyping |
I cut VO by hand in ProTools or Peak. I'm sure the Waves plug may do some heavy lifting for a sung vocal but it's more efficient to do it by hand if one cares at all about the final result. Sometimes a fade is necessary and there is no one stop band aid for that. It's case by case.
It's definetely case by case and by its worst, probably note by note. I have a guitarist who breathes so heavily that sometimes it's hard to tell whether his breathing makes more noise than his guitar.
Stuff he plays is top notch so I just have to deal with it. But it can surely be tiresome to fix it sometimes.
the waves works as well as doing it manually 80% of the time. the other 20% you get your hands dirty. and, of course, you don't normally want to eliminate the sounds, in most cases, merely reducing them 3-6 db usually does the trick. really oughta try it sometime. in the case of the op, he's facing hundreds of these and the waves ver is a fast and quality way for most of them. e
ihatetyping |
I think a Glock is a pretty good solution...you use it to get the singers to learn how to use "breath control"...I'm sure there's tons of information on the subject on the 'net...
I mean...did you ever hear Sinatra breathe? How about Elvis...or John Lennon...or Robert Plant? Since most of their stuff was pre-Pro Tools there was no way of cutting out a breath, so they obviously used proper breath control...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
recorded on HD9 but editing on 003r, is that okay? | grendizer | Pro Tools TDM Systems (Win) | 5 | 08-26-2011 09:04 AM |
New person - how to reduce static on voice recording | Norden | Tips & Tricks | 7 | 05-23-2010 10:02 AM |
Disabling Voice should reduce CPU usage right? | log62000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-01-2008 07:00 PM |
Editing audio recorded on HD with LE? | larsonjj | General Discussion | 4 | 09-10-2007 11:04 PM |
when fades don't reduce (or eliminate) pops | cc1 | Pro Tools TDM Systems (Mac) | 0 | 09-22-2006 10:22 PM |
