#51
Re: New 2011 MacBook Pro i7 has fan running loud and fast with PT9
I know this may be wrong but why not use, smc Fan Control.
#52
Tim |
#53
I tried the SMC fancontrol software and it does nothing to reduce fan rotation whatsoever.
I tried booting in 32 bit mode to see if this would make a difference, and it did but only a little. Whats really strange is when I look at activity monitor it's not like I'm totally maxing out the computer's cpu either. In protools my cpu meter will typically be between 20 to 46% running on 7 out of 8 chips. There's definitely something fishy and I just don't have the technical expertise to tackle this beyond what I've done and researched so far. It's really a shame too, cause the MBP is a kikass unit, more powerful than an HD4 setup hands down!
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
#54
So I have been using an 15" i7 2.4 for about 6 months now. I use it as my primary Mix/edit rig with Protools10HD. When I run it off the built in I/O I am able to keep the fans from spinning too high. I usually run it with an external USB interface (Apogee Duet2) and an external 30" CinemaDisplay though and the fans are "blasting" away! When I first started using it I thought the MBP was going to lift off! In my case I believe it is the 30" external display that forces the ATI Grafix card to kick in and thus creating more head. So the fans spin at full blast.
I learned to live with it but am also looking in to ways of cooling the laptop to keep the fans from spinning so high. Since I use PTHD10 and its RAM caching feature I no longer need an external drive to playback audio so all my audio is stored on the internal drive. Over all this setup blows away my old HD3 system when it comes to performance. |
#55
I'll keep you posted. Tim 17" Macbook Pro 2.3 GHz quad i7 8gb ram OSX 10.6.8. |
#56
The fans do get loud---bummer. Tim |
#57
Hi guys, I have the same problem with my MBP with i7 and 8 GB of ram. Bought in April 2011. At beginning I had System 10.6.8. Interface used: MBox 3 or FW Digi 8 rack or internal with Aggregate.
High temperature just opening a simple session, fans always on at higher velocities, frezee during recording....It is crazy!!! I spend a lot of money to buy this MBP just to have a great portable system. It was better my old MBP, with some limitations but worked well everytime. After troubles and thousands of phone call to Apple (I have Apple Care), they first changed hard disk. At beginning seems to be better but same problems. After they changed all the mother board. Better but impossible to use without problems of heating or fans at full speed.... but just for stupid operations. I formatted the new hard disk, intalled Lion 10.7.2, fresh, Pro tools fresh, plug ins, just that I need and with attention for compatibility. Now at 44.1/24 session, works well, no problems, sometimes fans starts, but it is normal. Impossible to use at 96/24. Just with 6 tracks, only a Waves IR1 for reverb, 6 Digi EQ, some busses... nothing so special: fans are always at full speed, heat od DIE Cpu more than 98° celsius... so I will use my hammer on it! Sometimes I have same problems with Skype, Firefox! It is crazy for a professional computer like this!!! I will set up like SKYKO said in his message. |
PT11HD on 2011 MacBook Pro | ksgltd | Pro Tools 11 | 13 | 01-11-2016 02:15 AM |
MacBook Pro 13" (late 2011) with PT 10 | musikasik | macOS | 5 | 01-12-2013 10:29 AM |
nubee- Which firewire cable do I use for Macbook Pro 2011 | s1rdelek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-23-2011 04:10 PM |
Early 2011 MacBook Pro | DJTezo411 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-27-2011 12:55 PM |
2011 MacBook Pro/PT9 Graphics Freeze | dnadig | macOS | 5 | 03-25-2011 12:40 PM |
