Old 10-22-2005, 09:58 AM
jrs320 jrs320 is offline
Default Can I change the default output on a new track?
When I create a new audio track it always defaults to the top choice on the menu. Is it possible to make it open to a different one? I work at a place where when you create a track it opens on the 5.1 output which makes the sub woofer go nuts. It would be great to change that to the output down the line which is their normal output.
Thanks for any help.
Old 10-22-2005, 10:35 AM
Drew Mazurek's Avatar
Default Re: Can I change the default output on a new track?
go to Setups menu--I/O Setups.
www.drewmazurek.com
Old 10-23-2005, 07:10 PM
Thank you very much, that worked like a charm.
Default track output not saved c-tone Pro Tools TDM Systems (Mac) 11 10-11-2013 05:29 PM
Can't change my default output bus Talisker macOS 3 01-11-2012 04:18 AM
Default Output On New Track Siegfried Meier macOS 7 10-14-2011 09:21 AM
New Track Default Output (bug) Roivas Pro Tools M-Powered (Mac) 6 06-14-2010 04:04 PM
change default midi output in 7.1 dgilbert Pro Tools M-Powered (Mac) 0 11-24-2007 01:47 PM
