Re: Digi 002 Standalone mode problem with digital
ive only ever used coax spdif as i use optical for ADAT, while they should work the same i would not be surprised if problems only relate to one. there was some bug in PT with coax/optical at one stage, i cant remember what it was as it didnt consern me. i used to run my computer sound into spdif and every so often ill go to standalone mode so i can but in general its just not worth it. i find when clocked from the computer soundcard there isnt much difference in quality than just running to the alt-in and its much simplier than going into standalone mode. if you want better quality for listening to music use the wave driver |
EDIT: Update: Wave drivers work for iTunes, but not for games (well, the one game I tried: Starcraft ). If I'm gonna use it, its got to work for everything. Maybe analog i/o is the easiest, but I am determined to get to the bottom of this optical 48kHz SPDIF sync problem. Has ANYONE tried to replicate this problem yet?
Digi002/PT 7.3.1 Shuttle XPC SB61G2: P4 (2.8GHz), 1Gb RAM, 80Gb SP0812N (System), 160Gb SP1614N (Data), DVDRW, NVidia 7600GS |
ill try optical in when ive got time |
This is a very good solution, many, many thanks! By all means please double-check the optical 48kHz when you have time - it would be good to get confirmation of that bug so that Digi can work on a fix.
So its back to the dodgy optical spdif for me, although I might just admit defeat for now and use the analog cable until digi fixes this. ANY help replicating this bug is still very much appreciated (please see initial posts).
Digi 002 Standalone Mode and MIDI | agprimatic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-09-2010 06:50 PM |
Digi 002 Standalone Mode | DJ Mozaic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-29-2010 06:19 AM |
002 switch between standalone/PT mode is a problem | C Room | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-17-2004 11:46 AM |
Digi 001 w/NI Kontakt (Standalone Mode Problem) | Earthling | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-06-2004 07:13 AM |
Digi 001 w/NI Kontakt (Standalone Mode Problem) | Earthling | Tips & Tricks | 0 | 02-10-2004 09:34 PM |
