Old 10-05-2022, 07:56 PM
tomhartman tomhartman is offline
Default SAVE A COPY Causing Problems
Getting this error:
Could not save a copy in "Copy of Every Kind of People" because (-1) while copying "EG1 2_01.wav" to "EG1 2_01.wav".
Any ideas?
Thx
TH
Old 10-05-2022, 08:54 PM
audiolex1 audiolex1 is offline
Default Re: SAVE A COPY Causing Problems
Originally Posted by tomhartman View Post
Getting this error:
Any ideas?
Thx
TH
Metadata could be corrupt. I've seen it before a long while ago. Try doing a region consolidate so it creates a new file and then try your save session.
Another option is. Create a new session, select copy audio and import the tracks you want just for that session.
This option will often fix any internal corruption that might have happened.
I just use the 2nd one honestly. Have been for 20 years and it never fails.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 10-06-2022, 11:37 AM
This happened to me last week and I also posted about it. But in that case PT immediately quit when I tried to SAVE A COPY. Will be trying again today on another session and will report back. I did indeed consolidate the problematic track but received the same error message...
Problems with "Save Copy In" from Network Storage trevorbalbierz Pro Tools 2019 2 09-28-2021 01:27 AM
Save Session Copy doesn't copy all files within the bin anymore Farhoof Pro Tools 12 13 11-27-2015 09:11 AM
'save copy in' problems ??? Darksun Pro Tools 9 4 01-29-2014 07:46 PM
Problems with Save Copy in... ? Anyone else? audiogeekzine General Discussion 2 04-16-2009 10:13 AM
'save session copy in' problems with 6.1 and Reason mykhal c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-16-2003 03:35 PM
