Old 09-06-2021, 11:24 AM
Pete89 Pete89 is offline
Default Pro Tools "Not responding" every 45 seconds
Just installed Pro Tools and I am seeing a Not Responding every 45 seconds. The program just freezes. I dont have any apps open at the time it happens. This happens just after a reboot and login. I am attaching a trace file from Windows Procmon that tell all about what is going on. I ran the trace only for a few seconds while the PC was "not responding". I don't see any smoking gun but maybe there is some Reg/File/CPU maestro who can read the tea leaves.
Well, I could not attach the trace file.....
Hmmm not too sure what I can do next. Let me know if you would like to see the trace file and I can get it to you.
Many thanks,
Pete89
Old 09-06-2021, 03:58 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro Tools "Not responding" every 45 seconds
Do you have any expired demo plug-ins? Are you using an iLok or iLok Cloud?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-07-2021, 01:28 AM
This installation is one day old, and literally I have done nothing so far to the configuration. Here are some screen shots. This is starting to smell like a reinstall of Windows.
Old 09-07-2021, 07:18 AM
Sadly, the screen shots are a bit too fuzzy to read for me. "every 45 seconds" sounds to me like some program is running in the background and tries to "phone home" every 45 seconds. Giving us full details on the computer might help get better advice.
Having said that, I would run Malwarebytes anti-malware and Ccleaner to clean the Registry(run it over and over until it finds no issues)
Old 09-07-2021, 07:26 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by albee1952 View Post
...Malwarebytes anti-malware and Ccleaner to clean the Registry(run it over and over until it finds no issues)
+1. Another one I like is SuperAntiSpyware Free Edition. It even has a "quick scan" option that works pretty well.
Click for audio/video demo
Click for resume
Old 09-07-2021, 08:31 PM
scenaria scenaria is offline
I had a similar issue on a MacBook. Turned out I was losing cloud authorization. I had the MacBook on Wi-Fi and it was hardwired over Ethernet to the d-control. Problem was for whatever reason it would persist to use hardwire as internet connection and then drop authorization which resulted in a freeze
Old 09-07-2021, 08:40 PM
TrentWilliams TrentWilliams is offline
If you're on a Mac:
Disable Time Machine, or use TimeMachineEditor to schedule backups outside of work hours.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 09-07-2021, 09:01 PM
Eric Lambert's Avatar
Originally Posted by TrentWilliams View Post
If you're on a Mac:
I had a similar thought but he's on a PC.
In Mac-land, the computer can often check to see which external drives are still connected, and it's been an issue for PT for years, but I don't know if Windows interrupts its apps in the same way.
I will say that the latest two iterations of PT have been beachball-laden. I'd go back 3 versions (to safety) but I rather enjoy some of the new things in the latest version.
Being Mac-specific again (sorry), I've experienced similar odd delays about every minute which were fixed by nothing more complicated than resetting PRAM (now called NVRAM). I also wonder if Windows has a similar BIOS-level management scheme that can become corrupt and need resetting every once in a while...?
Old 09-08-2021, 01:42 AM
Thanks for all the input, but in the end I wiped the PC and did a reinstall of Windows and so far, so good.
I don't think it was a resource issue as there was plenty of available RAM and CPU, and I didn't see any network connections opening up at the time it froze, but I ran of patience and quit troubleshooting.
Now on to recording!!
Thanks again
Pete
Old 09-08-2021, 06:16 AM
Thanks again
Pete
Now that things are working, this is the perfect time to save a drive image of your C: drive
Pro Tools 12.5 "Not Responding" ouibjamn Pro Tools 12 13 01-24-2018 05:27 PM
"Application Not Responding" When I Separate Clips in Pro Tools 10 Red Door Recordings Pro Tools 10 3 08-11-2015 02:43 PM
Pro Tools "Not Responding" While Bouncing Audio to Disk OTPBAND Pro Tools Express on Windows 3 12-20-2014 03:33 AM
"Pro Tools not responding" error and a very "laggy" session! Help! drumbumd Pro Tools M-Powered (Win) 0 02-10-2012 05:37 PM
" Not responding" msg in win7 while starting pro tools v9 q8test Windows 2 07-31-2011 10:54 AM
