Old 01-19-2017, 04:10 AM
Amelnik Amelnik is offline
Default AAF import on existing tracks clears Volume Automation
Hi everyone!
The bug i found today is: Importing AAF on existing tracks clears Volume Automation on whole track length.
So if we work on some track and then decided to add some clips to it through AAF import - we lose all volume automation on this track.
The workaround is: import AAF on new track and then move clips to desired track.
Old 01-19-2017, 04:28 AM
joachim's Avatar
joachim joachim is offline
Default Re: AAF import on existing tracks clears Volume Automation
Even if you deselect all Automation types for "Track Data to Import" in the menu ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 01-19-2017, 06:48 AM
Drew Mazurek's Avatar
Also check for an offset in the start time between the two sessions. Your automation may be there, just further down the timeline.
www.drewmazurek.com
Old 01-19-2017, 01:48 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
This is my standard operating procedure with AAF/OMF.
I will choose,
Freewill
http://jimdiazaudio.com/
Import OMF preserving volume automation Rumsound macOS 8 12-02-2013 03:57 PM
Import tracks and move them to an existing track Downtown_BE macOS 2 08-30-2012 11:42 AM
Possible to import volume automation from OMF? Aaron_PT_User Post - Surround - Video 6 04-05-2006 10:01 AM
volume change with existing automation Brain Digger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 01-31-2006 10:26 PM
trim down all existing automation - on all tracks? MixerGuy Pro Tools TDM Systems (Mac) 14 01-20-2006 09:29 AM
