AC3 file created w/Compressor had wrong byte order
I've recently encoded an AC3 file with my MacBook Pro using Apple's Compressor application. The file is to be MUX'ed with an MPEG-2 stream for playback from a dedicated server in an on site installation. A co-vendor's MUXing application is unable to recognize my .ac3 file. I have a file inspection application from Manzanita Systems that also fails to recognize the .ac3 file created by Compressor.
I found this thread in the Apple forums: Apple Compressor Forum Thread Then I found this bit of info online: Quote:
Then I looked at an .ac3 file that I created with Compressor on a G5 in back in October '06. It began with 0B 77. It was also recognized by Manzanita's MPEG-ID application. I can't find anything on Apple's website regarding this issue. No Knowledge Base article; no update; nothing. WTF? Anyone using the latest version of Compressor on an Intel based Mac to create AC3 files? Having problems sending them out to people who are NOT using DVD Studio Pro to handle the files further? Right now, I'm looking for a utility app that can perform a byte reversal on an entire file. In a month, I've got to be on the road with the ability to make AC3 files on my laptop. Thanks for any insight. j mcd |
Re: AC3 file created w/Compressor had wrong byte order
There are three types of AC3 files: normal, normal+timecode, and PC. The first two use a big-endian byte order and "normal" is the most standard format and that is what Compressor is creating. It does not matter if you use a PPC or Mac Intel computer. Compressor is programmed to create the same kind of file no matter what kind of computer you use. The PC file type uses little-endian byte order and is required by some applications. Those applications should be improved to accept any type of AC3 file. An alternative to Compressor is to use the SoundCode For Dolby Digital plug-in. It can create any file type and can be used with Pro Tools LE/M-Powered on a laptop on a Mac or a PC. Even though Pro Tools LE/M-Powered is not a surround app, you can place each channel of a 5.1 surround mix on a separate track, highlight all six tracks, and encode it. The decoder will decode a 5.1 AC3 file into six mono tracks for confidence testing.
Paul www.neyrinck.com |
It is appropriate that two versions (big-endian and little-endian) of a single file format exists using the same extension? Do "aware" apps just look at the first two bytes, or is there info in a header? There's also the issue that, although DVD Studio Pro can handle both types, it can't use them both in the same project. I will have to fire up a G5 with the latest version of Compressor to run some tests of my own. j mcd |
I Googled "byte swap utility" and there is some stuff out there but I could not find an appropriate one for OS X. You need to find something that byte swaps 16-bit words. Paul |
OMNI 7.1 order wrong? | David Sandwisch | Pro Tools HDX & HD Native Systems (Mac) | 8 | 07-16-2013 11:24 AM |
Wrong file is being played and waveform is wrong | jmullins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-30-2010 12:29 AM |
fades rendering incorrectly - wrong fade created | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-06-2008 11:41 PM |
ac3 file byte order bug confirmed - solution found | John McDaniel | Post - Surround - Video | 2 | 02-28-2007 07:04 PM |
wrong dates on "session created/last opened etc." | jlcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-24-2006 09:30 PM |
