seperate video drive?
hello,
I am currently running a small sound design set up. Do I need a seperate video drive to play back clients videos? or should i keep the video files on my audio drive with my protools sessions? Thanks for your help! Dan My current set up (any suggestions are very helpful) Mac G5 Mbox 2 PT LE 7 Dv toolkit 2 Command 8 Lacie 250GB External drive for Protools Sessions 250GB Internal hard drive for sound design & music library www.soundbydesign.tv |
Re: seperate video drive?
Definitely a separate drive and most reliably a separate buss.
For instance in a simple setup I use FW drives for audio and stream my video off of an internal ATA drive. Or vice versa. Looking at your setup you might want to have a second internal drive, or at least partition the one so that your system is separate from media. |
Thanks for your advice!
I run my video off my audio drive with no problem. But I do commercial post and rarely have anything longer than 60 seconds or more than 16 tracks. I did do a 30 minute film with about 32 tracks with no problems. If you have long videos and high track counts, go for it. if not, you'll be fine.
Dave Kaduk Particle Audio |
Installing plugins on a seperate drive | mashtbn | Pro Tools HDX & HD Native Systems (Mac) | 12 | 05-24-2021 03:01 AM |
partitioning a 2 TB or seperate drive to record? | rgriff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-17-2013 10:10 AM |
No Audio, But Just Samples. System Drive Or Seperate Drive. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-10-2010 03:47 PM |
will protools seperate audio from video?? | joeydego | Pro Tools M-Powered (Win) | 2 | 07-30-2010 06:28 AM |
SEPERATE INTERNAL HARD DRIVE | cfinch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-12-2008 08:30 AM |
