Old 02-18-2005, 08:05 AM
spong spong is offline
Default Problems with itunes and mbox
Everything else works fine throught the Mbox, (acid, windows media player, etc) however, when I try to get itunes to work I get a weird delay/echo/skipping kind of thing. I am using the wavedriver and MME helper.
It was working fine, but I had to reformat my c drive and reinstall everything and now it doesn't work.
any Ideas, thanks.
cheers
spong
Old 02-18-2005, 09:47 AM
Default Re: Problems with itunes and mbox
You just have to increase the buffer size in the QuickTime preferences.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-18-2005, 11:17 AM
I couldn't find the quicktime preferences you were talking about.
However, I managed to get it working okay by disabling my sound card via the hardware device manager.
thanks
cheers
spong
Old 02-18-2005, 11:22 AM
Run QuickTime Player (not iTunes).. and in the Edit menu select Preferences->QuickTime Preferences, select Sound Out and set your out as your MBox and press the Options button.
Rail
Platinum Samples
Mbox 2 sound problems when running itunes, stuttering, etc. Daviat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 41 11-29-2012 03:44 AM
Problemas Itunes! / Problems Itunes-Mbox MEPHISTOX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-29-2008 05:37 AM
Itunes through Mbox problems Flan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-03-2007 09:02 PM
iTunes 7.3 Problems????? sladlow Pro Tools M-Powered (Mac) 3 07-17-2007 12:15 AM
iTunes v7 problems, HELP!! mastershredder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-17-2007 05:29 PM
