Problems with Memory Location/Marker Import
Hi All,
I haven't found this specific problem anywhere, so I'd like to share it with you: I'm working on 5 sessions and now want to put them all together. Importing the playlists and clips isn't the problem, but when checking "import markers/memory locations", the markers are set to the beginning of the destination session, though the clips will appear at the correct Timecode. So all the Timecode options won't help. Whatever I try, whatever the timecode of the source session is, after importing, the markers will start right at the beginning of the destination session. I also tried exporting an re-importing via MIDI, same thing. Am I missing something real obvious here or is this actually some weird problem? I would appreciate any hint Thanks! T |
Re: Problems with Memory Location/Marker Import
Pro Tools' marker importing is pretty lackluster. Markers import relative to session start and take in no consideration of timecode whatsoever. If the first marker of your source is 1 minuted into the session then it will import 1 minute into your destination session. But if your source and destination sessions have different session start times then the imported markers will be off.
I suggest calculating the difference between the two start times and cut and past the imported markers to the adjusted start time. It's clumsy but it works. -Justin
Justin Walker |
It used to work as you'd expect in PT 9 - it's broken in PT 10.X
Justin's tip won't help if you've already got markers in your session - good luck there! You could import in reverse, import reel5's markers move them down, import reel4 etc etc. |
I ran into this today. The solution that worked best for me was to make the start time of each session the same and as a result the markers appeared where they were expected after importing. I hope in the next update/version that this is fixed.
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
I can export the markers, but can't import them (PT 10.3 - 10.5) another unfortunate thing is that when you export the markers the time reference is ALWAYS samples - NOT what you choose in the dialog box (unless in fact you CHOOSE samples.) another problem is that I can IMPORT them, nor can I import session settings (i.e. export session settings as text). ProTools/Avid says this a is a know issue. Does anyone know what that means?
Question about location marker | miketmbt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-24-2011 05:47 PM |
Import memory location: track show hide??? | audioluche | Pro Tools TDM Systems (Mac) | 2 | 01-20-2011 09:30 AM |
Memory Location Marker Does NOT Update After Edit Cuts | wdjudd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-09-2007 05:12 PM |
Problems w/ insertion point and memory location | carolmc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-13-2006 07:40 AM |
snap to memory marker? | Rob Macomber | Pro Tools TDM Systems (Mac) | 1 | 01-09-2002 12:18 AM |
