Removing unnecessary overdub files
I worked on a long (17 hours) session with a band in my studio this week-en. We nailed 5 songs for a high-quality demo CD.
Anyways, we created more than 15GB of data, but most of the data is files of multiple takes, and I'm only interested in keeping the current take for each track. I looked in the manual but didn't find the answer. How can I permanently erase all but the current files and save space on my disk?
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
Re: Removing unnecessary overdub files
In the edit window, click the "audio" tab above the bin where all your session audio files are. Then in the menu that pops up, go to "select"> "unused Regions" or "Unused Regions except whole files". Whichever you select, those files will be highlighted in the bin. Then once again click the audio tab and then select "clear selected". You will then be given the option to "remove" or "delete" the selected files. "Remove" only clears the files from view in the session (they will still be in the session audio folder) and "Delete" will remove them from the hard drive.
Sorry for being off topic but j20056 what equipment are you using (and what digidesign hardware??)
Digi 002 Rack Win XP Athlon XP 2700 / ASUS A7XVX-X DAVEC 32 + 8 without breaking a sweat |
my equipment list would fill up 2 pages. as far as Digi, I use a 001 to track, and I mix on an MBox.
i love my apple iPhone! |
Do the 'Delete Unused Regions' thing then save the session using the 'Save Session Copy In ..' command. Check the saved files load and play, then you can either delete or back up the original files to CDR. Check the new file sizes - loads smaller because you've only saved the visible files.
removing files | paldry | macOS | 1 | 02-27-2011 08:52 AM |
Assertion errors when PT deletes unnecessary files | Mixchump | Pro Tools TDM Systems (Mac) | 3 | 11-19-2008 10:39 AM |
Loading 6.7. Will I lose files by removing 6.4 1st | Ross H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-19-2004 07:06 PM |
Removing unwanted audio files from project | C.G. Kelway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-15-2004 06:40 AM |
SUGGESTIONS FOR REMOVING UNNECESSARY SYSTEM ITEMS!?!?! | pobox7310 | Pro Tools TDM Systems (Mac) | 3 | 11-25-2000 12:36 AM |
