Old 03-13-2001, 08:35 AM
rusmooth rusmooth is offline
Default Minimum memory required for PTLE 5.1
It's stated in the book that came with PTLE 5.1 that "at least 256 Meg of RAM is required" to run on Win98SE. The online compatibility document still says "192 Meg RAM recommended". Does 5.1 need the higher ammount?
Old 03-13-2001, 11:46 PM
ReniuR ReniuR is offline
Default Re: Minimum memory required for PTLE 5.1
I'm not sure if it "needs" 256 as a minimum, but I would recommend having that much anyway. 256 is a good, solid amount of ram. I run 512 megs of ram.
-ReniuR
www.disposableproductions.com
Old 03-14-2001, 08:23 AM
DigiTechSupt's Avatar
I believe the manual is incorrect. Pro Tools LE requires a minimum of 128MB RAM to launch. However, 192MB or higher is strongly recommended.
Brent
Avid Audio Tech Support
Support FAQ
Old 03-15-2001, 11:09 AM
DigiTechSupt got it exactly.
but I still recommend 256 megs, give it some head-room, and dimm's are getting SO cheap now...
-ReniuR
Old 03-15-2001, 11:37 AM
Jopry Jopry is offline
definately go with 256. I was running 5.0.1 with 128 with no hitch. upgraded to 5.1 and most of my sessions will not play now (they will all load). so, now I'm waiting for another 128 mg of RAM to come in.
Jared
Jared O'Pry
Question about ProTools looping playback in timeline - minimum length required? natez311 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-21-2010 10:13 PM
minimum memory allocation for dae/PTLE dcurran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-04-2002 09:27 AM
Where can I find a list of minimum required extensions for mac/PTLE? dturner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-01-2002 03:12 AM
Minimum Extensions Required to Run DP3 and PTLE? monkey finger-toes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-23-2002 06:02 AM
never change minimum required memory ?? Chris Lambrechts Pro Tools TDM Systems (Mac) 7 09-05-2000 04:31 PM
