Avid Link Fails to install Downloaded software Enable UAC Install failed
New to Protools and the Avid Link where all the downloaded software is: fails to install products. In windows I have tried to run Avid Link as administrator
I am the administrator. Any how the protools plugins are a probem now. I managed to find Protools download and bypass Advid link and I did install it manually by running as admin. Problem is Avid Link can't install anything that is in the Q and probably never will. This is the entire message Install error: Pro tools install failed. Administrator Level authentication is needed to complete installation. Enable UAC and retry t he install in order to enter the necessary credentials. So what i need is to find out where all the Advid downloaded plugin are located so I can manually install them Thanks for your comments. |
Re: Avid Link Fails to install Downloaded software Enable UAC Install failed
I found the download directory and I will unpack and install manually but if anyone knows how to fix the avid link let me know
Windows Controlled Folder Access is most likely the problem. Microsoft set that to "on" by default when they rolled it out which interferes with installers that create folders/files in your Documents folder (which Pro Tools does for preset storage.) Highly irritating move by Microsoft (this is completely separate from UAC.)
Follow the instructions here in reverse to disable this "feature." You only need to do the Windows Security App section. https://learn.microsoft.com/en-us/mi...o365-worldwide You can re-enable it after doing the installations if you want (just remember you'll have to disable again on any updates.)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Avid Link won’t install PT updates | hw2nw | macOS | 2 | 07-03-2022 04:10 PM |
Install failing at Avid Link stage | romanlohyn | Pro Tools | 1 | 07-09-2021 04:02 AM |
Avid Link not showing correct PT 2019.5 install status | taylor4814 | Pro Tools 2019 | 1 | 05-18-2019 09:11 AM |
AVID QT codec install on Lion failed | Frank Kruse | Post - Surround - Video | 1 | 10-31-2011 12:53 PM |
