#41
Re: Can\'t get 002 WDM driver to work
One more thing to check. Do you have an ATI Radeon video card? If so, it's quite likely that the Rage Theater drivers are the problem.
#42
I'm using nvidia geforce fx go5200 video
#43
bump again
#44
am i the only one with this issue?
#45
Yes.. unfortunately I'm on my second session of the day.. and the cab file you sent me last night I couldn't open on my Mac at home.. so haven't had the time to look at your report today yet. I did notice that you have a MOTU FW interface... and a bunch of other FW devices. Try turning all those off and restarting XP and then seeing if there's a difference. The dal service is running so we're going to have to figure out what's causing the issue/conflict. You may need to reduce your system down to a minimum and start adding hardware/drivers one at a time 'til you find the culprit.
Rail
Will 10.5.1 driver work with 10.5.2 OS ? | driver49 | Pro Tools M-Powered (Mac) | 0 | 03-09-2008 11:31 AM |
Coreaudio driver won't work | Hanslemonverm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2006 06:59 PM |
Wave Driver doesn't seem to work at all... | GiantMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-21-2004 03:06 PM |
Can't get the ASIO driver to work... | Rammelt | Pro Tools TDM Systems (Win) | 8 | 10-30-2003 05:03 PM |
6.1.1 CoreAudio Driver does it work for you? | Mark Wheaton | Pro Tools TDM Systems (Mac) | 1 | 09-23-2003 04:56 PM |
