#21
Re: Can\'t get 002 WDM driver to work
No DIGI devices use WDM. They have ASIO and WaveDriver. You will have to uninstall PT, then install WaveDriver. It should work from this point. If you're golden, then you should be able to install PT 6.1.1 or higher and things should still work correctly.
#22
#23
#24
By the way,
You guys saying that Digi doesn't provide WDM drivers are wrong. WDM stands for windows driver model and without a WDM driver model, you would be unable to use the 002 as a windows media player. In fact, the name of the wave file driver is dalWDM.sys ! |
#25
By the way,
You guys saying that Digi doesn't provide WDM drivers are wrong. WDM stands for windows driver model and without a WDM driver model, you would be unable to use the 002 as a windows media player. In fact, the name of the wave file driver is dalWDM.sys. |
#26
bump
#27
If you upgraded to 6.1.1 or better, you have to remove the wave driver, then unistall PT, then reinstall PT, then upgrade to 6.1.1 or 6.4, THEN install the wave driver. All should work at that point. This is all spelled out in Digi documentation. |
#28
#29
"The Digidesign WaveDriver v6.1.1 can also be installed as standalone if no version of Pro Tools is installed." That is exactly how I installed that. When that didn't work, I installed the complete 6.1.1 LE CD including drivers. When that didn't work, I installed the 6.4 update including drivers. I've uninstalled and reinstalled everything several times including booting into safe mode and manually removing all digi* drivers according to http://answerbase.digidesign.com/detail.cfm?DID=6209 I then reinstalled the wave drivers and that didn't work either. I've never had any pro tools earlier than 6.1.1 so I'm not sure what your comment is there. Am I speaking french? |
#30
Have you followed my steps in your other thread for reinstalling Pro Tools.
Can you run a Sandra Report and email it to me in HTML format zipped. Rail
Will 10.5.1 driver work with 10.5.2 OS ? | driver49 | Pro Tools M-Powered (Mac) | 0 | 03-09-2008 11:31 AM |
Coreaudio driver won't work | Hanslemonverm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2006 06:59 PM |
Wave Driver doesn't seem to work at all... | GiantMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-21-2004 03:06 PM |
Can't get the ASIO driver to work... | Rammelt | Pro Tools TDM Systems (Win) | 8 | 10-30-2003 05:03 PM |
6.1.1 CoreAudio Driver does it work for you? | Mark Wheaton | Pro Tools TDM Systems (Mac) | 1 | 09-23-2003 04:56 PM |
