not an audio playback volume
I just purchased a 002R, everything seems fine. I created a new session with no problems. Here's the hitch. When I copy my saved work created using my 001 and PTLE 5.3 onto my freshly formatted drive (done according to the Getting Started specs), then try to open a session, I get the error that the volume in not an audio playback volume. This happens when I get the message that the current disk allocation is not available and it wants me to check the disk allocation. I select the custom option and the location of the files and then I get the error. If I cancel this step it will open the session but states that the wave files are in an unsuitable location and wants me to copy them. Same results.
I'm at a loss. Is there a method for importing older work that I'm not aware of? Thanks in advance. |
Re: not an audio playback volume
You have to have the audio files on a valid Playback audio drive.. check the drive setting in the Workspace window.. each drive will have a letter under the A (for Audio) and V (for Video) as to its capabilities.
Rail
I checked the Workspace and the Audio column was set to Transfer. When I tried to change to Record the message box told me the volume in question was not a valid audio volume.
Next step? Thanks |
Ensure that you have DMA enabed in Hadware Devices for your IDE controller.. if all else fails you'll not be able to use that drive for playback and recording... I have some partitions on my system which aren't "valid audio drives" too.. even tho' they technically are set up correctly.
Rail
Make sure your drive is formatted as a primary partition in windows ( See disk Management in XP help). I had this problem even though I thought I had set it to be one but it still wasn't so I reformatted. This is so PT doesn't think you are trying to use a RAID ( I think! )
Hello,
There are two kinds of Drive Signatures: Basic and Dynamic. You need to use a Basic volume for audio playback and recording. You can check this by right clicking on My Computer go to Manage > Storage > Disk Management. On the right hand side you will see all drives connected to the system. Check the Drive "Type" to see if it is Basic or Dynamic. If the drive is listed as Dynamic you will need to reformat the drive as a Basic Disk to use it with Pro Tools. I hope this helps. Mike |
The disk management tool doesn't let me define the drive as basic, it automatically assigns it as dynamic.
Suggestions? Ooops. I just check the help on disk management and was able to change the drive type to basic. It's formatting now. |
That did it...
This little tid bit of information should be included in the 'Getting Started' documentation. Once the drive type was set to basic the volume was automatically set to Record in the workspace. Thanks for all of your help. Colin |
xx is not an audio playback volume | bazeboiee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 11-28-2011 10:23 PM |
Audio Playback volume? | ZedLeppelin | Pro Tools M-Powered (Win) | 1 | 10-19-2009 08:44 PM |
Audio playback volume? | Lonald | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-19-2007 08:20 PM |
Audio playback volume? | Lonald | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-19-2007 04:15 PM |
"not an audio playback volume" | JDavenport | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-15-2004 07:50 AM |
