need help sync mpc 2500 as master and le 7.1.1 slv
i need help slaving le 7.1.1 i know how to set the mpc as the master but i dont know how to slave 7.1.1
Re: need help sync mpc 2500 as master and le 7.1.1 slv
When recording or monitoring, Pro Tools can
synchronize to an external clock source. Op- tions for external clock vary according to the type of Pro Tools system you are using. Pro Tools can receive external clock from the Optical input or S/PDIF input. To select an external clock source for a Digi 002 or Digi 002 Rack system: 1 Choose Setup > Hardware. 2 Set the Clock Source to match the type of in- put. 3 If you choose Optical, make sure the Optical Format matches the type of optical input you are sending to your Pro Tools system. If you set the Optical Format to S/PDIF, Pro Tools will watch the Optical port for ex- ternal clock, and ignore any clock input on the S/PDIF RCA jacks. Page 532 in the manual. As always, RTFM.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Pro Tools (Master) sync (MPC 2500 Slave) troubles... | Connecticut | macOS | 2 | 07-06-2011 06:16 PM |
MPC 2500 and PT8/Mac/002 won't sync at all | geetar777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-14-2009 05:45 PM |
MIDI SYNC problem with MPC 2500 | D the Great | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-09-2008 10:00 AM |
need help sync mpc 2500 as master | crowdpusha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-29-2007 09:43 PM |
help sync-ing mpc 2500 to le 7.0 | crowdpusha | MIDI | 5 | 09-14-2006 04:54 PM |
