Old 11-12-2023, 06:38 PM
tomhartman tomhartman is offline
Default Pro Tools Click Problem
Imported a midi file into Pro Tools which is set to 45 BPM... really slow. In addition, it has several meter changes.
I'm seeing that the click, which should be on every quarter note, sometimes stops and only clicks on the first downbeat of the next bar or so, then picks back up to being on every beat like it should. Any ideas? Never have seen this.
PT
Old 11-13-2023, 12:25 PM
Default Re: Pro Tools Click Problem
PT
Hi Tom
More info might help
Pro Tools version?
You just using Click II on the standard click track or are you running a custom MIDI track?
What does the MIDI import have to do with the click? Does the click mess up before you import anything?
Can you share a session, (maybe just a badly performing click track)?
Old 11-13-2023, 12:30 PM
2023.6
Midi file contains tempo info and time sig changes.
Using the normal Click 2.
Will upload it later, in session now, thanks!
MTRX Sample Rate Change = Click click Click Crash Jeff Schmidt Pro Tools | MTRX & MTRX Studio 5 11-16-2021 10:13 AM
6.9 LE Click Problem Michael King 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-08-2006 02:10 PM
Pro tools m-powered digital click problem!! Thomserendk Pro Tools M-Powered (Win) 13 04-19-2006 06:13 AM
Pro Tools 6 Click problem Great Divide Studios Pro Tools TDM Systems (Mac) 3 03-08-2003 08:04 AM
Click Problem Sugarite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-08-2001 12:34 AM
