Old 08-14-2023, 08:13 AM
anackman's Avatar
anackman anackman is offline
Default Pro Tools Unresponsive after Audio File Catalog Quit
Still having this freezing/unresponsive issue when closing a session with the Audio File Catalog dialog box. Pro Tools gets stuck with Audio Catalog box on screen after hitting File > Quit.
Even on OSX Monterray and Pro Tools 2023.6 it happens. Prefs have been trashed many times. Might be plugin related, but I am having trouble finding a pattern. The issue has occurred on sessions with many plugins and brand new sessions with almost no plugins.
I have to force quit Pro Tools in order to get the session closed once the 'Audio File Catalog" window pops up.
MAC OS Ventura
Pro Tools 2024.3
2020 iMac 27" 3.2 Ghz i5, 64GB Ram
UA Apollo Rackmount Thunderbolt + Dangerous D-Box
2x Glyph Studio 2TB Raid SSD
Old 11-01-2023, 09:14 PM
bionic bionic is offline
Default Re: Pro Tools Unresponsive after Audio File Catalog Quit
Same bug here. Seems to occur when I run in Rosetta mode too as I don't recall it happening sans-Rosetta?
Pro Tools HD 12, Mac Pro 12 Core 4GHz, HDX, Waves, 12 Terabytes WD Caviar HDDs, 32 Gig 2000MHz RAM, EMM Labs Convertors, LYNX, Neumann, Wunder, Purple, AKG, Rola, API, Neve, Pultec
Old 11-02-2023, 05:05 AM
JingleDjango JingleDjango is offline
Also here. Most often on sessions with a large number of audio files, usually my score mix projects. Problem is intermittent.
macOS 12.5.1
PT 2023.9
EUCON 2023.6
S1 & Control App on FireHD 10 (2021)
Old 11-16-2023, 09:20 AM
marianna's Avatar
marianna marianna is offline
Alex
thanks for posting... I did create a case for this ( 04710763 ) and referred the techs to your other case as well when PT had to force quit.
Randall has asked you a few things but didnt hear back on that one.... such as: :
Please check if the iLok License Manager has pending updates, if so, please install them, after that try to re-sync the iLok USB Key.
Please check if the issue happens with and without plugins inserted
Please disconnect the Glyph server and verify if the issue persisted.
Anyway they will look at this one too.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 11-16-2023, 09:23 AM
marianna's Avatar
Hello Bionic...
Love to create a case for you but cant as your email used here is not your MyAvd email... can you DM me or email me it at [email protected]
Thanks as the more with the issue - the easier it is to reproduce and then fix.
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Old 11-16-2023, 09:28 AM
marianna's Avatar
macOS 12.5.1
PT 2023.9
EUCON 2023.6
Hi JingleDjango
I created a case for you.... 04710776. - even though it is intermittent, try to answer the questions they might ask. Between the 3 of you with this issue, maybe they can pin point it.
Thanks
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
Renaming "region+file" causes unexpected quit Paul Daniels 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2005 08:38 AM
FW drive/Catalog file entry not found for extent Robocop Pro Tools TDM Systems (Mac) 2 06-20-2005 01:31 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
Compressing a Pro Tools file to a Audio file (Mp3) Funkmaster69 Tips & Tricks 7 02-26-2004 11:08 AM
