  #31
Old 08-09-2021, 05:00 PM
Perfect Record Perfect Record is offline
Default Re: 2021.6 Colours are different
Originally Posted by Kyle Splittgerber View Post
The legacy settings (saturation and brightness) for track headers don't map perfectly to updates we made for UI Customization. This is due to the wider range of adjustments that are now possible. What you'll want to do is manually make those adjustments in Window > Color Palette > UI Customization to get it close to what you're used to. These UI settings are system based, so you only need to adjust them once.
Kyle,
What I'm noticing is that on my M1 Mac under Big Sur 11.1 on PT 2021.7, that I get the colored tabs at the bottom of the mix strips, but the actual strip remains gray.
On the color window, when "tracks" is selected in pull down, I don't have the button to apply color to tracks, that used to be just to the right of the dropdown.
I don't see a replacement for that button in the UI Customization tabs.
BTW, M1 Mac is not my daily driver. I'm transitioning to it and working through compatibility issues as they arise, on PT and interfaces ETC.
  #32
Old 08-09-2021, 05:08 PM
JFreak's Avatar
JFreak JFreak is online now
Hi, welcome to the community.
Maybe the problem is your OS version then? PT 2021.7 is supported on 11.4 (and later as per my tests, current Big Sur works well). Who knows what the 11.1 adds to the mix.
Janne
  #33
Old 08-11-2021, 10:10 AM
devinemke's Avatar
devinemke devinemke is offline
in the Color Palette window under UI Customization under Tracks, adjust the Track Header Brightness and Track Header Saturation. see attached screenshot:
File Type: jpg Screen Shot 2021-08-11 at 1.04.04 PM.jpg (38.6 KB, 0 views)
Devin Emke
Audio Post Production
Saturday Night Live, NBC
  #34
Old 10-20-2021, 06:53 AM
zigzawya zigzawya is offline
+1 for a Legacy Option
  #35
Old 10-20-2021, 08:28 AM
francois's Avatar
francois francois is offline
+1
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
  #36
Old 10-20-2021, 01:36 PM
Originally Posted by francois View Post
+1
That already exists - you can go back to the original pallette in the PT preferences.
Jack
QAPLA!
  #37
Old 10-28-2021, 10:25 AM
devinemke's Avatar
happy to report that the issue with track colors not matching there headers/footers (mentioned early in this thread) has now been fixed in Pro Tools 2021.10. see attached screen shot. thanks.
File Type: jpg Screen Shot 2021-10-28 at 1.21.42 PM.jpg (74.2 KB, 0 views)
Devin Emke
  #38
Old 10-28-2021, 11:20 AM
Nice but that never bothered me.
Jack
QAPLA!
  #39
Old 10-28-2021, 08:51 PM
ZEUSS ZEUSS is offline
Excellent!!
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
  #40
Old 03-16-2022, 09:21 AM
ponderifica ponderifica is offline
Default Re: Colours are different in 2021.6
Adding back to this -
I am noticing this issue having just updated a month or so ago.
It seems there is a less overall saturation in the track header. Even at 100%, its just simply not as saturated as it once was.
This is something I relate to with the OP, as I heavily rely on a color system to navigate quickly and these more dull colored tracks are really making that a bit more difficult.
2021.6 and 2021.7 restart after exit NJsound.com Pro Tools 12 08-11-2021 01:45 PM
2021.6 colours? midnightrambler Pro Tools 6 07-29-2021 08:47 AM
Clip colours Reckless Erik Pro Tools 2018 0 03-07-2018 06:50 AM
Memory Colours? Neurosis Pro Tools 12 2 06-12-2016 10:59 AM
