Old 06-18-2021, 08:19 PM
MixerGuy MixerGuy is offline
Default Snap highlighted fader to S1 fader 1 WITH no mixer window shift …?
Hi all
I am hoping there is a way to do this:
How I currently do this is whatever fader in the mix window that I am working on
To get it to fader 1 on my s1 WITHOUT SHIFTING WHERE MY MIX WINDOW IS ALIGNED I click once on a random fader way to the right in the mix window
Then I come back and click on the fader I want in the mix window to be fader 1 on my s 1 and that works perfectly.
Just a little slow.
And yes I know there is a right click command (and also a key command) to snap the current mix window fader to s1 fader # 1 BUT that also snaps that fader in the mix window to the far left and I do NOT want that to happen. As it messes up my mixer window view of how I like things arranged. (My active fader central -ish on my mix window dedicated visual monitor screen …not all the way to the left. )
Hope this makes sense - and hoping there is a way to do this. :-/
Old 06-19-2021, 12:45 PM
BScout BScout is offline
Default Re: Snap highlighted fader to S1 fader 1 WITH no mixer window shift …?
In Pro Tools, Setup>Preferences>Mixing:
Uncheck "Mix Window Follows Bank Selection"
In Eucontrol, General, "Auto-bank to clicked track"
(But not "auto-bank selected track" though -- you get one or the other but this one won't necessarily move the selected track to the fader 1; if the selected track is already visible on the S1, it just moves selection. If it is not visible on the S1, then it'll move it to fader 1 to make it visible)
Old 06-19-2021, 02:50 PM
Thanks so much. I will try this out soon.
And just curious - I’m unsure - if I click on a fader that is already on fader 2-8 on S1 will it hop to fader 1?
Thx.
Old 06-19-2021, 03:13 PM
No. If you want that, hold shift+control when you click on a track (Mac shortcut keys)
Old 06-19-2021, 03:33 PM
Thanks - but IIRC that will also snap the virtual fader in mixer window to far left and I usually don’t want that. As it is way too far left.
Thanks tho.
Old 06-19-2021, 04:14 PM
Thanks tho.
Yes. Shift+Control+click will bank the Mix Window.
If you just want the clicked fader to be on the first S1 fader, why don't you just use Eucontrol layouts and assign S1, fader 1 to Attentioned Track?
Old 06-19-2021, 04:52 PM
Because I generally know the order of my faders…
And if I have flute as fader 1, I am usually guaranteed to then have oboe on 2, clarinet on 3 and bassoon on 4, for example. So if I want to grab bassoon fader I know it is on 4.
However it might be worth the compromise to always have selected fader on fader 1, and just be mindful of my group status always. So I could ride the string section if I knew the string group was on….
Thx.
How to open fader from mixer in single, new window? TRNCFRMCN Pro Tools 12 2 09-02-2016 04:48 AM
Mixer fader in edit window like logic. Possible? imz14u Pro Tools M-Powered (Mac) 3 09-09-2015 11:48 AM
Is there is a way to have Pro Tools Mixer/Editing Window to Follow the selected fader AMIEL Artist Series 9 03-09-2015 07:56 AM
Fader snap bug Jperkins macOS 3 01-09-2015 02:07 PM
Snap Fader to 0 db Soundtrack2life 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2008 05:37 PM
