Help with Kensington Expert Mouse (trackball)
Is there a PT application set for this thing and can anyone share if they have it? I'm attempting to make the switch from hocky puck to trackball and so far I am liking it...just would love to use those extra six buttons across the top for inside-protools functions. The directions just tell me how to lauch websites and other applications. Thanks!
J.Ho |
Re: Help with Kensington Expert Mouse (trackball)
actually you can program the 6 top buttons with the latest version of MouseWorks, the control panel that controls it.
Go to the page where you pick the button's function. Hold down option and you'll get the full menu. Now you can assign them to tool selections, or whatever. There is no pre-made application set for PT, everybody sets it up for their own thing. There have been a few threads where people listed their own custon settings,you can do a search for it. My set is this: bottom left-click bottom right -double click top left-zoom tool top right-smart tool quick launch buttons: 1-save as 2-delete selected tracks 3-bars and beats 4-mins/secs 5-page back (edit window jumps left) 6-next page (edit window jumps right) |
For OS9.x the latest seems to be 5.7. Does PT need to be up when you start programming? Or basically I need to write down my keystrokes and then program them, right?
J.Ho |
If the mouseworks utillity ain't working for you, try a handy utillity called 'USB Overdrive'.
It is a control panel and extension that replaces your mousedriver and allows you to assign any keycommand/click combination to any button. Better still, you can make different setups for different programs as well. Works great. Cheerio, Joris (btw, it works with any usb mouse/trackball, regardless of the vendor) |
Captain Crunch, could you (or someone else) explain how you made the top 6 DirectLaunch buttons access non-shortcutted menu items such as Save As, Delete Selected Tracks, and selecting the main time scale. I would love to make a custom response to access the Preferences dialog to temporarily turn on/off settings without having to scroll the menu. The tip about holding down the option key: BRILLIANCE! I probably would have never learned that. Custom responses have saved my life. Thanks.
Stein Tore
Stein Tore Sønsteli Pro Tools Ultimate 2023.12 (HDX-2), Mac Studio M1 Max, MTRX Studio, Avid I/O's, S1 + Dock |
You need to specify system 9 or 10. I think the top buttons are only programmable w the Mouseworks that's for OSX. Use quickeys for menu actions etc and trigger the quickeys hot keys w the Kensington. Also the new scrolling support in 6.1 is great w that track ball w scroll speed ste to "very fast".
<<If the mouseworks utillity ain't working for you, try a handy utillity called 'USB Overdrive'. It is a control panel and extension that replaces your mousedriver and allows you to assign any keycommand/click combination to any button.>>
Do you run "Mouseworks" and "USB Overdrive" at the same time or do you not need "Mouseworks" when using "USB Overdrive"?
Dan Matthews InSight Sound Recording Loveland, CO (970) 663-1650 InSight Sound Web Page |
By the way, the newest driver on the Kensington site is the one you want to use. I had problems using the older OSX version and 10.2.5...the newest driver (2.03 I think) and 10.2.6 seems to be fine...
I've got mine set the same way I had it in OS9 (the newest driver also added back in the full launcher functionality) - which is cool because I never need to use the Dock: top left - Finder top right - double-click those two together - application launcher bottom left - click bottom right - Option-click those two together - Shift click Mouse Speed.....FAST... You can get to a bunch of things in PT with those choices... S..
"it's not about making the changes, it's about playing ideas in time" Scofield... |
kensington expert mouse trackball | cananball | Post - Surround - Video | 57 | 10-26-2014 06:13 AM |
Kensington Expert Mouse Optical Trackball - Program/Usage | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-02-2007 02:53 AM |
Kensington Expert Mouse question | mhayes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-16-2006 06:29 PM |
Kensington Expert Mouse with 6.9 | mariang | Pro Tools TDM Systems (Mac) | 9 | 09-18-2005 03:48 PM |
Using PT 5.3.1 with Quickeys and Kensington Expert Mouse Pro | Siegfried Meier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-11-2003 06:36 AM |
