192 Output Calibration w/ PreSonus Monitor Station
Hey folks,
I'm experiencing an interesting problem at the studio that I could use some help with. We have a very simple setup. We only use Analog out 1&2 on our 192 I/O for monitoring and mix everything inside the box. There's no console involved. The problem we're having is that no matter how much we crank down the 192 output trim pots below the D-Sub connector, Protools output seems to be hitting the PreSonus Monitor Station about 4dB too hard and mixes sound distorted above about -4dB. Is this a common problem/known issue with this particular monitoring box? Maybe there's some coarser gain adjustment for 192 outputs somewhere else? Thanks, Travis |
Re: 192 Output Calibration w/ PreSonus Monitor Station
The Monitor Station's Tech Specs list the maximum input level to be +22dBu. If your 192 is calibrated at -20dBFS = 0dBVU = +4dBu, then 0dBFS = +24dBu at your output. So you are clipping the input to the monitor station by at least 2dB. You should be able to calibrate your 192 to -18dBFS = 0dBVU = +4dBu so that 0dBFS = +22dBu.
Send MONO 1kHz -18dBFS sine wave out to a single output at a time. Measure the AC RMS voltage across the + & - pins of the output with a multimeter. Then adjust the output trim on the 192 until you get a voltage reading of 1.228 volts AC RMS. Repeat for all the 192 outputs. (It would be a good idea to calibrate the inputs too.) You should now be calibrated to the correct operating level to match with the Monitor Station. But if you are constantly mixing with levels at the very top range of the scale, i.e. mixing through an L2 with levels constantly near 0dBFS, then you will always be running the Monitor Station near its clipping point and getting much higher levels of THD than if your levels were running closer to the 0VU range. I would say in that case that it would be safer to calibrate the 192 to -16dBFS = 0VU, but I'm not sure if the 192 will calibrate to that level. HTH
Scott Gatteño |
Same problem here but with PreSonus Central Station.
Please Help. Hamdi |
Does not the post above yours help? ff
Just wondering why you guys don't run digital to CentralSt?
I've cal'd 192's to -14 before, it'll go to -16 easily.
... but does it help the chorus? |
Good to know. Thanks Sean!
I have never had to calibrate to anything other than -20, and the info seemed hard to find in the 192 user guide, which doesn't list ANY specifications for some reason. Also, for the OP, make sure you are using the correct set of Trim Pots on the back of the 192. There is an A trim and a B trim for each input or output. These are selectable in the Analog Input and Analog Output tabs of the Hardware Setup window.
Scott Gatteño |
I have one setup with central station that has no problems with PT's outputs. I have another setup with monitor station and I have to gain the correct trim all the way down but still I have to lower the master fader by 10db to keep away from red light in monitor station. It's like it was built for -10 but the manual claims balanced +4.
Mac Pro 8 core Nehalem 2x2.26 GHz Quad-Core Intel Xeon, 15 GB ram, HD2 Accel, 192 I/O, PT 10, Mac OS 10.6.8. Dedicated internal drives for system and sample libraries. Recording few tracks on a network Synology NAS. More tracks on a Western Digital external FW800 drive. VI's from NI (Komplete 7), Toontrack, Spectrasonics, IK Multimedia, Vienna, MOTU (BPM), Ivory and a bunch of other plugs. |
Is there a jumper or switch for -10/+4?
I've used one in a private overdub suite (a 002 room) and it seemed clean.
is it better throught spdif or optical?
FS: Presonus Monitor Station | AV Pro | Buy & Sell | 0 | 05-16-2013 04:03 PM |
Presonus Monitor Station....does it badly color the sound? | drguitar | macOS | 11 | 03-23-2011 10:41 PM |
Mbox to PreSonus Monitor Station | jmo1112 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-16-2009 02:04 PM |
PreSonus Monitor Station = Questions | J FRANK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 34 | 09-18-2008 07:15 AM |
D/A better on 888/24 or Presonus Central Station? | Black Frog | Pro Tools TDM Systems (Mac) | 1 | 10-29-2004 09:22 AM |
