minimising mic "sss" and "tttt" sounds in singing
title may not be the best, but I had a friend around recording some vocal tracks for some music he's working on, he has quite a clear and slightly upper class english speaking voice, which means he pronounces his words very clearly. When signing I found certain letters are "popping" with the mic.
For example if he sang the line "ship" I'd get a hiss on the "sh" and a "pop" on the "p". I'm using a pop shield, and tried moving him a little further away from the mic to try to get clear vocals but without the sh, ch, t and p's from picking up so bad. Any basic tips on this. thanks. |
Re: minimising mic "sss" and "tttt" sounds in singing
Some things to try:
1) Move him a little off axis, so he is talking more across the mic than directly into it. That can be off axis over or under as well. 2) Try using 2 pop filters. The popper stopper type is much better IMO than the foam type. 3) Use a de-esser plug-in for anything remaining. Hope that helps! |
no problem, I'll move him around more, I was going closer/further away, didn't try angles, seems very worth trying.
two pop shields....ok, can do, I do have two funny enough. de-esser plug-in sounds good, didn't know that existed so I know what to research now. Big help, thanks. |
Hey Matt,
"upper class english speaking voice" aside.., what microphone are you using ?? I suggest swap mics around, before any plug-in processing. best of luck
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Using a Trusty Rhode N1
I did try a few others and it didn't make enough of a difference to warrant swapping. I rely too much on the N1 and a few other mics so I think it's time to invest in a few others less generic. |
http://www.masseyplugins.com/ |
I learnt about massey plugins a few weeks ago from this very forum, I was very impressed so appriciate the pointer at the massey de-esser plugin, I'll be looking into that shortly.
Steve Massey is a great guy and I consider his plugs the next best money spent after the VST2RTAS wrapper.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Blocking the "P" and "F" sounds in vocal tracks. | ice0-5 | Tips & Tricks | 6 | 03-18-2011 10:20 AM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
Removing "Ph" and "S" sounds in vocals | India001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-22-2001 06:24 PM |
