64-bit drivers?
I'm currently downloading Digi's Snow Leopard compatible update 8.03, which was announced earlier today. I also plan to update drivers for my FireWire 410, Transit, and Micro, which I notice are available in 32-bit and 64-bit versions.
I have a mid-2009, unibody MacBook Pro, which can run 64-bit programs. I know that Pro Tools is not 64-bit, but I'm assuming I should install the 64-bit versions of the drivers. What would be the advantage of these over the 32-bit drivers? I'm fairly certain I should install the 64-bit drivers, but thought I'd solicit the collective wisdom of the DUC. Thanks for any advice or clarification!
MacBook Pro Max, Apple M1 Max, 64 GB RAM, Pro Tools 2021.12; Sibelius 2021.12 |
Re: 64-bit drivers?
Snow Leopard does not boot in to the 64-bit kernel by default. At some point in the future Apple will probably have all systems boot into the 64-bit kernel by default. You can force Snow Leopard to boot to the 64-bit kernel if you want. If the kernel is running in 32-bit mode (default with today's Snow Leopard), only the 32-bit kernel extensions (drivers) will run. |
Re: 64-bit drivers?
Thanks, Bob. I was under the impression that Snow Leopard could run 64-bit-capable applications in 64-bit mode regardless of whether it has booted into a 64-bit or 32-bit kernel, e.g. Activity Monitor lists Mail, Safari, etc. as running as 64-bit applications.
But I guess what you're suggesting is that the drivers are kernel extensions, not applications. That's where my confusion was. I wonder why M-Audio is making 64-bit drivers even available at this point. Christopher
Re: 64-bit drivers?
In case anyone had the same question I had, after much searching I found this posted by Paul from M-Audio Tech Support regarding the 32- and 64-bit drivers: "We have been trying to get this changed to a single listing, but it hasn't been done yet. It is the very same driver in both listings (32 and 64 bit)."
003 Drivers | tmitchell | Pro Tools 10 | 6 | 10-27-2013 03:24 PM |
Drivers | MandoDjango | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-19-2009 10:51 AM |
Drivers | sykobilly65 | Pro Tools M-Powered (Win) | 4 | 09-23-2005 06:18 PM |
HUI drivers.... | edytnbch | Pro Tools TDM Systems (Mac) | 1 | 04-12-2005 04:14 PM |
OSX drivers or proprietary PT6 drivers-what will it be? | pfd4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-02-2003 02:04 PM |
