#1021
Re: i7 Builds - Specs and Results
These are the 2 options I'm down to - any thoughts?
Cheers, Rikttt Option 1 CORE i7 920 / 2.66GHz / 4.8GT QPI / 8MB CACHE / LGA1366 1 Gigabyte GA-EX58-UD3R Motherboard 1 Gigabyte Radeon HD4650, 1G, DDR2, DVI, HDMI 1 Kingston 6GB 1333MHz DDR3 CL9 DIMM (Kit of 3) 1 620W "Corsair" HX-620 ATX Modular Power Supply, 120mm 1 Antec Nine Hundred -- Ultimate Gaming Cases - Black, NO PSU 1 CAVIAR BLACK / 750GB / 7200RPM / SATA 3GB / s / 32MB CACHE 1 CAVIAR BLACK / 500GB / 7200RPM / SATA 3GB / s / 32MB CACHE 2 LGE GH22-NS30 22 x Dual Layer Black OEM - SATA 1 Option 2 CORE i7 920 / 2.66GHz / 4.8GT QPI / 8MB CACHE / LGA1366 1 P6T Asus P6T Motherboard 1 Asus Radeon 4350, 512MB, DDR2, DVI, HDMI 1 Kingston 6GB 1333MHz DDR3 CL9 DIMM (Kit of 3) 1 750W "Corsair" TX-750 ATX Power Supply, 140mm fan, Dual 1 Lian Li PC-60F Aluminum Mid Tower Case - Black 1 CAVIAR BLACK / 750GB / 7200RPM / SATA 3GB / s / 32MB CACHE 1 CAVIAR BLACK / 500GB / 7200RPM / SATA 3GB / s / 32MB CACHE 2 LGE GH22-NS30 22 x Dual Layer Black OEM - SATA 1
PTLE8.x Mbox, Sibelius, Record, Reason, i7 D0, UD3R rev1.6, GEIL 6GB KIT EVO ONE C9 2000Mhz, Noctua NH-U12P SE1366, CavBlacks 2x 500G + 1xT, SAPPHIRE HD 2400PRO 256MB SILENT, CORSAIR 750W, Novation Remote SL37, Win7. . |
#1022
Take the setup in option 1. then there are 2 things you can do to make it even better 1. Swap the case for Antec P182. 2. get a 512MB version of the display card. Also consider a Corsair 520HX would do (with tons of headroom). You don't need the extra 100W in the 620. Put the diffrence in upgrading the 750GB HD to 1TB. Didnt see any CPU cooler on your list? I recommend you get one (especailly if you plan any OC)
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#1023
Thanks dude,
I'll order the Noctua NH-U12P, unless you can recommmend a better one. As far as I can see this fits onto the mobo into a P182 no worries, but my Australian retailer tells me the P182 has been replaced by the P183. Will this be okay? Apart from $$$, what's the advantage of losing 100W on the PSU and halving the display card memory? Any preference between these two cards: Gigabyte GV R467D3-512I Graphics adapter - 512 MB - GDDR3 SDRAM Sapphire PCIe 2.0 HD4650 512MB HDMI HM ATI PCIE2.0 Thanks again!
PTLE8.x Mbox, Sibelius, Record, Reason, i7 D0, UD3R rev1.6, GEIL 6GB KIT EVO ONE C9 2000Mhz, Noctua NH-U12P SE1366, CavBlacks 2x 500G + 1xT, SAPPHIRE HD 2400PRO 256MB SILENT, CORSAIR 750W, Novation Remote SL37, Win7. . Last edited by rikttt; 05-19-2009 at 03:40 AM. Reason: add info |
#1024
I'm not sure if I want to spend more time (again) trying to get XP Pro to run.. Everything is working as smooth as it can and I don't miss any drivers or such in Win7.. I'm gonna wait untill Win7 is released and buy me an upgrade as soon as I need it (i.e. when this one expires next year). I'm hoping Pro Tools will release a 64 bit version before that time so I can upgrade to 64 bit Win 7 with 64 bit PT.. I know there's a lot going on already with Win7 64 bit, but as I've glanced through that topic it will work okay with an (USB) Mbox, which I have now, but as I'm upgrading to a 002 this week, I think I'll just stick to this version (32bit).. Next step is that I'll send it to Black Lion Audio for one of their Signature mods.. |
#1025
Lower W PSU simply means cheaper, yet as effective. With regards to lower GPU mem, some say it plays better with the way windows and Protools use RAM, but I haven't noticed any diffrence myself. I have used this model of gigabyte and I know its kinda noizy. If you don't plan any gaming then find a passive card with 512MB of memory or less. However if you do want to game on the same machine then bump it up to 4770.
#1026
i would keep the 620w psu. the i7 uses quite a bit of power compared to previous builds and if you drop in a couple more hard drives, have 5 flash drives plugged in and pci or 2 in the future you should be safe. drop to a 512 or even a 256 mb vid card.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#1027
if you dont have one already, track down a cheap ps/2 style keyboard. sometimes when building the machine, the wireless keyboards and even usb keyboards can be a problem. also at least a usb mouse.
#1028
#1029
OCZ DDR3 1600 on sale at the newegg for 69.00 after rebate for eblast email subscribers. Also free shipping during the memorial day sale.
Just a heads up.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#1030
Okay ladz I finally made my decision and changed to i7 chip. I ordered my parts today so I guess I'm in the group now
Okay here's the big list: MoBo: Asus P6T, Intel X58, S1366, PCI-E 2.0 (x16), Triple DDR3 2000(OC), SATA 3Gb/s, SATA RAID, ATX CPU: Intel Core i7 920, D0 (SLBEJ) - S1366 (B), Nehalem, 2.66GHz, 8MB Cache RAM: Corsair 3GB (3x1GB) DDR3 1600MHz XMS3 Dominator Memory CL8 (8-8-8--24) HDD 1: Samsung SpinPoint F1 HD103UJ 1TB Hard Drive SATAII *32MB Cache* (This deive will be halfed later [500GB-500GB]. 1st part will have the OS and the 2nd part will have my files) HDD 2: Western Digital WD3200AAKS 320GB SATAII 16MB Cache 7200 RPM - OEM (This drive is for only Pro Tools 8 LE) CPU Cooler: Akasa Nero Intel Socket 1366, 775, 939, AM2, AM2+ Processor Cooler PSU: 700W TruePower PSU GPU: evGA Nvidia GeForce 9800 GX2 1GB (2X512MB) GDDR3 KO Edition Case: Cooler Master Storm Sniper Case ATX Tower with Control Center for Lights & Fans Drive(s): Pioneer DVD-RW DVR-116D Drive, LG DVD Reader OS: Microsoft Windows XP Professional SP3 32-bit + Belkin 3-Port Firewire PCI Card with the Texas Instruments chipset which I removed from my old PC (Do I have to use this to get my Mbox 2 Pro working, because this MoBo's Firewire chipset is VIA.) I'll be running this PC with an Mbox 2 Pro... Let me know what you guys think about it! EDIT - Note that I already ordered these parts but I'll be able to change if its really necessairy! |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
