Should I just re-install Reason
I had Reason running on my G3 , no problem's , now I've transferred it to my G4 it , work's then it doesn't work , I have been through the DUC looking at all the previous conversation's and followed the instructions about asio driver's which I had already downloaded from propellerheads but they gave me v.5.0 , is this an issue as the Digi INIT and Digi Direct I/O in my system extension's is v.5.1, can anyone help !
Re: Should I just re-install Reason
we need a more accurate desription of the problem.
Ok , I have managed to run reason on myG4 through the Digi 001 , and it works fine then I switch it off come back to it and it says 'sound driver problem , the sound driver used last time could not be selected , and when I go into preferences the direct I/O option has a big red cross beside it , any ideas?
do you still have the asio driver in the asio foilder in the reason folder? I didnt know reason supported direct i/o ?!?!?!
Im looking forward to reason 2.0, looks like a nice little workhorse.
Huh? |
Hiya ckerian , first you'll have to excuse my ignorance in re-posting my message a few times as I've been going back and forward through this mysterious thing we call DUC .Anyway the answer to your question is yes , it's in my ASIO drivers folder now as ASIO DigiDesign DirectIO
hmm... yeah you may want to reinstall. you do have the correct driver. also make sure that your sound control panel is set to built in and not digi
HELP WITH REASON 3.5 INSTALL? | gregesme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-30-2007 10:57 AM |
Issues With "Reason" on New Install - Need Help Please | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-20-2007 08:34 AM |
Reason dead on 6.9 Install. | Mishima | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-11-2005 07:45 PM |
Where do I find/Install REASON? | oralmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-17-2005 08:34 AM |
