Old 05-20-2023, 09:43 AM
Chris August Chris August is offline
Default Can't Select Things In Drop Down Menus
There are a handful of plugins that all of a sudden won't let me select something from the drop down menus.
2 examples...
Output's Arcade. I go to change the key and it lets me open the menu, but no matter what I click it just keeps the same key. It won't change no matter what.
Antares Auto Tune Access: I go to change the key or the scale and same thing... I select one and nothing happens. It just closes the drop down menu and keeps whatever was already there.
I'm on 2023.3 / OS 13.2.1 / M1 Native
It also happens even if I open in Rosetta...and it happened even before this latest PT update and before I went to Ventura.
Old 05-20-2023, 01:44 PM
nsureit nsureit is offline
Default Re: Can't Select Things In Drop Down Menus
Have you updated these plug-ins recently? It’s possible that the updated presets were installed in the wrong folder. Happened to me recently. I have two folders named “Documents”, and the updater installed the presets folders in the wrong one. I just moved them, and everything worked.
Old 05-20-2023, 02:48 PM
Hey! Yeah both have been updated recently. I don't have any presets on these particular plugins. Also, they work perfect in other DAWs. Its just Pro Tools.
12.7 / 10.12.3 Drop down menus stop functioning. A Chapman Pro Tools 12 11 04-04-2018 07:24 AM
Mix input drop down menus disappearing PT LE BinkBonk macOS 1 12-01-2016 08:48 PM
Need Help. Blank spaces in drop-down menus. mtobin767 Pro Tools 10 20 01-12-2016 05:58 AM
Missing AAX and RTAS in drop down menus orangedog AAX Plug-ins 10 05-13-2013 11:23 AM
Access drop down menus without mouse???????? gwattaloopy1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-29-2006 12:32 PM
