Coreaudiod errors on startup
Hi! I am a composer from the Seattle area and I purchased ProTools 10 because I will be learning it in a few months. Ever since installing ProTools, I have been seeing these errors on startup:
com.apple.audio.coreaudiod <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged. com.apple.audio.coreaudiod coreaudiod: _RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL. com.apple.audio.coreaudiod[97] _RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL. I have not seriously started using ProTools yet so I can't say whether there are other problems yet. I googled these errors and the closest thing I found was an Apple support thread where a guy figured out that ProTools caused this problem and he solved it somehow, but he did not offer any details or the solution itself. I have read that coreaudiod not responding and crashing the system is a known issue so I'd rather handle this issue now. When I remove the various Avid/Digidesign system LaunchAgents/Daemons and Startup Items, the problem goes away, but ProTools won't start. The only way to make ProTools run again is a clean uninstall and reinstall. So this is clearly a ProTools problem. In addition to learning what these errors mean and how to fix them, is there a way to use ProTools and disable all these startup processes? In my experience, these items usually cause more problems and system slow-down than good. The PACE folder also loads but interestingly enough, if I remove it to prevent it on startup, all my other iLok-protected software works, but not ProTools...Either way, I see no reason why I need all this stuff loaded up unless I'm actually launching the program. Any ideas? P.S. I did search and found o sufficient answer, so I hope I am not wasting anyone's time. Also I am running 10.6.8 in 64-bit mode and I do not plan on using any Digidesign hardware (running a 2011 Macbook Pro 2.3 i7, with a 6G SSD and 16 GB RAM). Thanks! |
Re: Coreaudiod errors on startup
You are finding these errors in system.log, correct? Quote:
Alright, this is the answer to the question I kept asking above. Unless you are seeing windows that say AVID core audio has unexpectedly quit, don't worry about it.
coreaudiod (Not Responding) | Grant@2020sound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-13-2009 08:44 PM |
coreaudiod (not responding) | Ziko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 10-13-2009 09:10 AM |
coreaudiod not responding - PT8 install | Rich Breen | Pro Tools TDM Systems (Mac) | 1 | 02-10-2009 11:59 AM |
DigiIO and DigiDAL errors at startup, PTLE+Panther | gitpicker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-09-2003 01:38 PM |
startup hanging, various errors | davidp158 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-30-2001 08:15 AM |
