  #31
Old 11-25-2021, 02:15 AM
dominicperry dominicperry is offline
Default Re: New Mac - M1 vs Mac Pro 2019
The 16 core CPU still has quite a high clock speed and there is a big price jump to the next step. There's a limit of 768GB RAM up to that point, and the 24 and 28 core can take 1.5TB.
  #32
Old 11-25-2021, 02:16 AM
[forum is only letting me post one sentence at a time!]
It's worth getting 6 (or 12) RAM DIMMS, which uses the triple-channel architecture for more speed. But don't buy Apple RAM - after market stuff is about 1/3rd of the price and just the same.
  #33
Old 11-25-2021, 02:18 AM
-actually - if it already has Apple RAM, then you need to work out if the cheapest thing to do is add two more sticks of Apple RAM, or take it all out and buy 6 sticks of something else. Although Apple and non-Apple stuff should work together, it doesn't always happen that way (due to different latency specs).
  #34
Old 11-25-2021, 02:58 AM
JFreak's Avatar
JFreak JFreak is offline
Obviously there are even cheaper sticks to try, but I have never experienced any trouble with www.macsales.com products. They are probably better than Apple Spec.
Janne
  #35
Old 01-06-2022, 08:10 AM
stargazer stargazer is offline
Has anybody got any experience with this store?
mac-factory (Mac Pro upgrades and others - Berlin)
https://www.ebay.com/str/macfactory
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
  #36
Old 01-06-2022, 11:05 PM
tonwurm's Avatar
tonwurm tonwurm is offline
I had a couple of ebay transactions with mac-factory ... no problems, everything was fine
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
  #37
Old 01-07-2022, 05:03 AM
Thank you, tonwurm!
  #38
Old 01-09-2022, 05:21 AM
mac-factory claim to use new and unused Macs and performs RAM and CPU upgrades.
They also only use new Intel Xeon processors and new RAM from high quality manufacturers such as Samsung, Hynix, Micron.
I want to be able to run as many virtual instruments as possible (using VE Pro if Pro Tools still is less efficient in that regard) along with audio tracks.
What would be most beneficial for sessions with lots of Instrument Tracks (mainly sample libraries but also soft-synths)?
1 Choosing a 24-core instead of a 16-core.
vs
2 Choosing 384GB instead of 192GB RAM.
  #39
Old 01-09-2022, 07:19 AM
Depends on how big the VI's are. Large orchestral templates with multiple articulations loaded of sampled instruments will need lots of memory.
Piles of synthesized sounds in an EDM/pop mix won't take very much at all.
Can you do a test?
Dominic
  #40
Old 01-09-2022, 08:27 AM
Thanks, Dominic!
It’s kind of a stupid question from me - of course more RAM is better when it comes to sample libraries, but on my MacPro 5,1 PT starts to get sluggish before I’m near my 128GB RAM limit.
I suppose/hope PT on a MP7,1 will use RAM in a more efficient way, and that it’d be wise to invest in as much memory as I can afford.
Regarding the 16- vs 24-core, I’ve seen some opinions here that the 16-core 3,2GHz with the faster CPU hits a sweet spot price/performance wise.
Price aside, would PT, especially with a large orchestral session (VIs mostly), perform marginally or a lot better running on a 24-core 2,7GHz machine?
Drive not seen in 2019.12, seen with 2019.6 Cryos Pro Tools 2019 0 05-30-2020 06:29 AM
HDX Ultimate - 2019.10 7 2019.12 - video export issues anguswoodhead Post - Surround - Video 2 03-09-2020 02:33 AM
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
