Protools 9 crashing on startup
Just installed a full copy of PT 9, then updated to 9.0.3, and when I try to open it it crashes (see details below). It seems to crash right after the dialog says "setting up midi". I use MolCP3, and I have the latest version installed (and it works totally fine in Logic, which I also have installed on the machine). I've already tried removing all non-digi plugins, repairing permissions, and multiple restarts to no avail. Anyone have any ideas? The details below suggest that PT crashes on thread 26, whatever that means.
System info: 4,1 MacPro 2.66 quad, 8GB RAM OS 10.6.7 Audio cards installed: RME HDSPE Raydat and RME HDSPE MADI Process: Pro Tools [553] Path: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 9.0.3 (9.0.3f81) Code Type: X86 (Native) Parent Process: launchd [125] Date/Time: 2011-08-02 20:22:25.491 -0700 OS Version: Mac OS X 10.6.7 (10J869) Report Version: 6 Interval Since Last Report: 1136035 sec Crashes Since Last Report: 10 Per-App Interval Since Last Report: 178 sec Per-App Crashes Since Last Report: 10 Anonymous UUID: A95B8294-6813-4D25-88CB-5AC93F5C7776 Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000000004ac Crashed Thread: 26 Thread 26 crashed with X86 Thread State (32-bit): eax: 0x00000000 ebx: 0x00000064 ecx: 0x0000004a edx: 0x000004a0 edi: 0x064bf400 esi: 0x0721fa28 ebp: 0xb0e04ab8 esp: 0xb0e04870 ss: 0x0000001f efl: 0x00010206 eip: 0x03e091c8 cs: 0x00000017 ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037 cr2: 0x000004ac Model: MacPro4,1, BootROM MP41.0081.B08, 4 processors, Quad-Core Intel Xeon, 2.66 GHz, 8 GB, SMC 1.39f5 Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB Memory Module: global_name AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.131.36.9) Bluetooth: Version 2.4.0f1, 2 service, 12 devices, 1 incoming serial ports Network Service: Ethernet 1, Ethernet, en0 Network Service: Ethernet 2, Ethernet, en1 PCI Card: pci10ee,3fc6, sppci_audio, Slot-3 PCI Card: pci-bridge, sppci_pci2pcibridge, Slot-4 PCI Card: pci1057,6, Slot-4@5,0,0 PCI Card: NVIDIA GeForce GT 120, Display, Slot-1 PCI Card: pci10ee,3fc6, sppci_audio, Slot-2 Serial ATA Device: HL-DT-ST DVD-RW GH41N Serial ATA Device: Hitachi HDE721064SLA360, 596.17 GB Serial ATA Device: ST31000528AS, 931.51 GB Serial ATA Device: ST31000528AS, 931.51 GB Serial ATA Device: Hitachi HDS721010CLA332, 931.51 GB USB Device: iLok, 0x088e, 0x5036, 0x5d100000 USB Device: eLicenser, 0x0819, 0x0101, 0x3a200000 USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0x5a110000 FireWire Device: built-in_hub, Up to 800 Mb/sec |
Re: Protools 9 crashing on startup
How many total I/O are you working with? It seems PT9 has some issues with devices that exceed the 32 I/O limit, particularly those with 48 or more.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
the most IO I would use is a stereo out for monitoring (likely just the stereo outs of the MacPro). Of course I can't even get to a place of selecting any audio interface, though... because PT won't open.
(edit) However, the most IO I have available is 100 (with the RME cards as an aggregate device). |
You've repaired permissions, but running this free program might help:
ProTools Prefs & Database Helper http://www.jcdeshaies.com/ I would select all the tick boxes before running it.
Pro Tools 2023.9 Ventura 13.6 |
ProTools 9 Keeps Crashing On Startup | rastro2 | Pro Tools 9 | 0 | 02-20-2014 01:17 PM |
Please Help!!! Protools 9.02 keep crashing during startup!!!!! | jothedrummer | macOS | 1 | 08-10-2011 07:34 PM |
Protools 6.4.1 Crashing at startup | thecave | Tips & Tricks | 2 | 11-10-2009 10:35 AM |
PT LE Crashing on Startup | beggehorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-18-2006 09:18 AM |
protools crashing on startup help please | barkingdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-21-2004 08:38 AM |
