PlugIns turn Mono tracks into Stereo Automatically
I was at a friend's studio (PT20/Mac) and when I put Addictive Trigger insert on a mono kick drum track, it automatically converted it to a stereo track. When I removed the insert, the track magically went back to mono. It did this when ever a plugin could choose if it would be mono/stereo, meaning a discreet mono plugin kept the track mono. But any plugin that is listed mono/stereo would always change a mono track into stereo. Like I said, when that plugin is removed, the track goes right back to mono. I scoured Google but couldn't find anything remotely close this. I'm thinking it must be a weird default somewhere but I couldn't locate anything in Preferences. Thx. |
Re: PlugIns turn Mono tracks into Stereo Automatically
This is the way its supposed to work. And it doesn't change a mono track into a stereo audio file. It simply does whatever the plugin you select is meant to do. Example, insert a Mono>stereo delay plugin. In bypass, it sounds(and acts) like a mono track. Enable the plugin and you can set different echo settings for left and right, creating a pseudo-stereo effect.
Thank You!
Mono Tracks Turned into Stereo Output by Plugins | ts1234 | Pro Tools | 2 | 04-15-2021 11:17 AM |
Copying plugins from stereo tracks to mono | MusicMadness | Pro Tools 2018 | 7 | 03-31-2019 06:49 PM |
How to turn a stereo track into mono | remusjacobs | Pro Tools 10 | 10 | 08-15-2012 09:47 PM |
Turn mono to stereo? | typhy | macOS | 7 | 10-06-2011 11:14 AM |
Turn Mono Room to Stereo? | ronstephens | Tips & Tricks | 3 | 03-09-2008 04:38 PM |
