Old 11-17-2007, 10:11 PM
Symetrick Symetrick is offline
Default Problems installing Pro Tools LE 6.4 Software Upgrade
I am currently running on an AMD Athlon Processor 3200+ with 2.20GHz and 1.00GB of RAM using Windows XP Home Edition. I currently own a Digidesign digi 001 and I am unable to upgrade to any other interface at the moment. Before purchasing the upgrade to LE 6.4 software I was running on the standard 5.1.1 software which wouldn't allow me to even install it. After I purchased the Pro Tools® LE 6.4 Software Upgrade for Digi 001 for Windows XP - DOWNLOAD ONLY I installed the program and when ever I try running it two error messages pop up, one reading "The procedure entry point_DsiGetHardwareMemoryBlockEndAddress@0 could not be located in the dynamic link library DSI.dll. Once I hit ok to that error another error pops up stating, A required DLL file, DAE.dll, was not found.. I tried running a google search for both DLL's and was unable to find anything to resolve my problem so I turned to the forums hoping a tech or someone with better experience could assist me. If i need to add anymore information as far as my computer specs or anything like that at all please let me know because I am a bit new to this.. Other than that if theres anyone who could assist me in getting my Pro Tools running again please help, I'd really appritiate it.
Thanks Sym
Old 11-18-2007, 12:56 PM
Default Re: Problems installing Pro Tools LE 6.4 Software Upgrade
Any suggestions or ideas as to what the problem is with the installation of my pro tools?
Old 11-18-2007, 01:58 PM
cherryrecording cherryrecording is offline
Are you using Win XP Service Pack 2? If so, you should try installing the PTLE 6.4cs9 for WinXP update. You could also try updating the Pace Interlok driver as well.
Old 11-18-2007, 04:08 PM
The Weed's Avatar
The Weed The Weed is offline
And you'll need the 6.4cs6 update along with also needing the 6.4cs9 update and the latest PACE Drivers.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-20-2007, 03:47 PM
Ok i did what you guys told me to do and i still get the same error messages =/.. Not sure whats going on.. And yes im using Win XP service pack2..
Old 11-26-2007, 09:11 PM
Hi, I am still unable to launch my Pro Tools LE 6.4cs9.. Ive done everything that was suggested to me and it still gives me the same errors. Can someone please help me fix my Pro Tools so I can finally launch and use it once again.. If I am unable to fix this problem then I basically spent 35$ for the 6.4 version for nothing.. =( Please help me.. Thank you in advance.
Old 11-26-2007, 09:30 PM
spkguitar's Avatar
It sounds like you have two different, conflicting versions of Pro Tools on your system. That's usually what causes DSI.dll and DAE.dll errors.
You should try to completely uninstall all traces Pro Tools (using the un-install utility) and re-installing.
Old 11-26-2007, 09:31 PM
JMS40 JMS40 is offline
Assuming you have a compatible chipset, a clean/fresh install of:
6.4
cs6
cs9
Latest Pace drivers
Should give you a working setup.
If you've followed that procedure, and your still having problems, you should follow the instructions in the General troubleshooting thread and post a detailed Sandra system report.
Old 11-27-2007, 08:16 PM
Thank You so much.. I feel kinda dumb that i didnt think of that myself but it works now.. The only problem I have now is i need a valid authorization code? I used the one that came with my digi 001 pro tools le 5.1.1 but it wont accept it.. I purchased the upgrade online, download only.. Im not to sure where i find the code for i dont have an inside cover to find it on.. Anyone know where i get my authorization code? Thanks
Old 11-27-2007, 08:22 PM
spkguitar's Avatar
If you purchased it online, as a download only, your auth code should be available in your order history in the digistore. Go to "Your Account", login, then click on "View Order Details/Tracking Number" next to your order. The auth code should be in that order information.
Installing for 13 Users - Pro Tools LE 8 Software upgrade princebuster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-01-2011 10:25 AM
Problems installing Upgrade Douglas I 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-29-2006 08:24 PM
problems installing software E-an 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-24-2003 05:15 PM
problems installing software 5.3.1 fedup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-02-2003 12:29 AM
problems installing upgrade to ptools 6 nattyl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-30-2003 09:44 AM
