Old 10-25-2022, 08:54 PM
Thp1973 Thp1973 is offline
Default Folder Routing
Is there a way to make a track in pro tools automatically route to the Folder/Bus when you drop a track on it?
This should be a feature in pro tools already but I always have to route tracks to it. I didn't know if there was a way to setup a hotkey or some other way to do it.
Old 10-25-2022, 08:59 PM
BScout BScout is offline
Default Re: Folder Routing
No
Old 10-27-2022, 12:24 AM
mattrixx mattrixx is offline
Yeah, I had been wondering the same.. I just keep a couple of different track with blanks in the folders o my template use the duplicate command to make sure new tracks are routed correctly with the folder.
It can catch you out big time, if you're not careful. I agree, that it should be a preference.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 11-08-2022, 08:55 AM
audiogamble audiogamble is offline
+1 - Would LOVE this option. I have encountered a total of zero situations where I would want a track within a routing folder to not be routed to that folder. At the very least, this should be a preference. It would be especially nice if when duplicating a track folder, if it created a new bus to route the tracks to. They could simply take some notes from how logic pro x works in this regard.
Old 12-09-2022, 12:10 PM
Only when creating a new Routing Folder by highlighting existing tracks and using the Move To New Folder command (cmd-opt-shift-N). Then you can check the small Route Tracks to New Folder checkbox. There's no way to do it with existing Routing Folders.
Scott Gatteño
Routing Folder Inside Routine Folder - Solo Issue John9281 Pro Tools 3 03-20-2022 10:43 PM
Serious Routing Folder Bug! DrewHarrison Pro Tools 2020 8 07-21-2021 02:26 PM
Routing folder issue musicman691 Pro Tools 2020 3 12-22-2020 02:00 PM
Routing folder+VCA mgoorevich Post - Surround - Video 12 09-30-2020 03:45 PM
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus XJENSEN Pro Tools 2020 7 04-24-2020 07:29 AM
