Old 03-14-2018, 03:26 PM
WildHoney WildHoney is offline
Default Convert .PTS to .PTX ?
Digging deep into the archives, hoping I can revive an old session from 2005. Anyone out there know how to convert an old .pts session to .ptx or .ptf or something else readable by PT 12?
Old 03-14-2018, 04:28 PM
BScout BScout is offline
Default Re: Convert .PTS to .PTX ?
Is it Pro Tools 4 or older? If it is Pro Tools 5 or later it can be opened with current Pro Tools. You have to start Pro Tools, File > Open Session and point to it.
Old 03-14-2018, 04:31 PM
Brilliant, thank you. I had been trying to open it from by right-clicking in the finder. Opening from inside PT worked great. Thanks!
Old 03-14-2018, 05:18 PM
Ah, but all the clips are misplaced on the timeline. . . .
Old 03-14-2018, 05:31 PM
YYR123's Avatar
YYR123 YYR123 is offline
Spot dialogue?
Right click > Spot
Daniel
Old 03-14-2018, 05:40 PM
Originally Posted by YYR123 View Post
Spot dialogue?
Right click > Spot
Had thought the same thing, and started working on it. It's an instrumental multitrack session and there are thousands of regions/clips and it seems like a lot of stuff had been copied and pasted, so I'm not sure if it's going to take longer to piece it all together again than it would to recreate from scratch. I've got one continuous stem that I can reference, but it seems like everything else would be spotting to original timestamp and then trying to fill in the blanks from there. . . . ugh
Old 03-14-2018, 06:04 PM
Try to do an import session data from the original PTS into a new PTX (this will work the same way.) Be wary about the import settings (offset, etc) to see if that might come in right.
Old 03-14-2018, 06:14 PM
Ah. Yes, I should have mentioned that I did import session data into a new PT 12 session, BUT I didn't play with the settings at all -- I just left them in the standard way I typically use. Will try that. Good thinking, thanks.
Convert PT 5.3.1 to 9 Buzz Moschetti macOS 4 03-13-2011 01:33 AM
Help convert a QT to mxf ChrisMac Post - Surround - Video 11 07-10-2009 01:03 PM
convert wav to rex Dr.Seuss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-15-2005 12:38 PM
Help me convert DP to PT5.3 duende Pro Tools TDM Systems (Mac) 3 04-12-2002 04:58 AM
convert Win 001 to Mac 001 sasquatch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-08-2001 05:56 AM
