#21
Re: Hard Drive for Pro Tools 11
Let me understand something ... U mean putting the samples on the system drive which is the intel ssd wouldnt cause a lower performance than a separate ssd??
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
#22
Heavy VI users will also run out of space on their SSD boot/system drives if using lots of samples. So first thing is what is your space budget for the samples you want to load? If it will fit, ... you have the SSD, so stop asking questions and just try it. You don't want to run SSDs right up near max capacity as it can hurt write performance (one reason to also over-provision the disk. I always leave 20% unformatted, manufacturer defaults are around 5-7% and a bit too low for good sustained write/GC performance... which a boot/system/sample drive does not really need, oh until you are trying to copy stuff over or do something similar, use it for some scratch/temp space etc. so yes for flexibility I still would tend to overprovision almost every SSD drive, even if its intended use is read-mostly). Darryl |
#23
#24
Working as a charm ....
I just bought a Samsung 840 with a GoFlex Seagate Thunderbolt adapter ... I hope this works well as a sample drive
#25
How does it have "TRiM enabled by default" when that is an OS setting? What OS are you running on? Sandforce controllers really do not need TRIM enabled and this can help cause problems/corruption/total failure on these controllers. And they are not all "ready to go" -- especially make sure you are running the latest firmware, there have been bug fixes pushed for some nasty problems.
#26
Darryl ... I think the guy is referring to the garbage collection system sandforce controllers benefit from ... anyway I've been using an Intel 520 SSD in my Macbook Pro for over a year and i didn't ever notice any lack of performance ... everything opens in a blink of an eye ...
Pro Tools HD with WD 3TB Hard Drive | stephenandthemockingbird | Pro Tools TDM Systems (Mac) | 3 | 02-04-2013 09:06 AM |
usb 2 hard drive for pro tools 9 use | georgeski | Windows | 5 | 04-06-2011 07:38 PM |
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there | huncke | Pro Tools TDM Systems (Win) | 6 | 02-23-2010 02:06 PM |
Pro Tools Needs it's Own Hard Drive? | romeoplank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-01-2007 09:21 AM |
Help with Pro Tools hard drive | SteveGarman | Pro Tools TDM Systems (Mac) | 4 | 03-23-2004 02:52 AM |
