Pro tools & Platform M+ faders zeroing.
Hi, I'm running PT 10 with a new icon platform m+ control surface & at a loss. When I let go of the fader it moves to 0~ irrespective of auto mode. The screen fader follows surface fader and remains in correct location when i release it while surface fader moves to 0~. Any recorded automation does not move the surface fader.
I tested m+ in reason using MCU and all fine. What have I neglected ? |
Re: Pro tools & Platform M+ faders zeroing.
Hi again, at first glance platform is working with PT 11.3.0.
A fader pops to 0 and moves with screen fader. My original issue was PT 10.3.10 downloaded from avid around 2012. |
Since Pro Tools doesn't use MCU, I assume you have it setup as a HUI device? I would look to Icon for support first
I was wrong about this solution, it's another USB power/platform m+ problem. PT 10 worked on another tablet that had only 1 USB port as well but that tablet probably provides more USB power. So, platform had the issue on Microsoft surface with hub but not Dell tablet with hub. Platform seems to have issue/need with USB power even if correctly powered with it's power supply. Last edited by NedW; 08-29-2022 at 01:40 PM. |
The platform m can be finicky about which usb slot it goes into..
but you have to set it to pro tools hui on the imap software, and then set it up as a hui device inpt.. |
There’s a legacy section for older versions of Pro Tools….you might get more help posting there.
zeroing regions count when starting new session from template | marcnyc | Pro Tools 10 | 6 | 11-20-2015 09:15 AM |
zeroing out clip gain | colinato | Post - Surround - Video | 4 | 12-07-2012 09:21 AM |
MC-Mix Not zeroing out with host application mixer "Digital Performer 7.2.3 | SB MIX | Artist Series | 1 | 07-07-2011 08:48 AM |
Zeroing EA | nod25 | General Discussion | 2 | 08-10-2009 10:47 PM |
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... | domsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-08-2004 07:06 PM |
