PT Losing keyboard focus
Anyone experiencing anything like this?
Quite frequently, since installing 2022.4 when hitting the 'tab' key, pro tools will lose edit window keyboard focus. The icon still shows that keyboard focus is on for the edit window, but none of the shortcuts work. When I toggle it off and on via the keyboard command or icon, it restores the functionality, until it triggers again. I initially though it was an issue with a keyboard maestro macro, or a custom hotkey i had set up, but it occurs with the keyboard maestro engine closed, and the default keyboard shortcuts. A Pro Tools restart seems to clear it up for a while, but it's been coming back quite a bit the last few weeks.
-Evan |
Re: PT Losing keyboard focus
If you are using dual screens this can be an issue. Assuming the mix window is selected, then edit window command focus instructions will be ignored.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
I’m well aware that if I click on another window, I won’t be able to input commands into another. This is related to the “az” keybaord focus commands in the edit window, not general window focus.
-Evan |
Just trying to help. The point was it is hard to see which window is on top when you have the edit window on one screen and the mix window on the other. My a-z becomes inactive on the window in the background.
Yes I have this exact problem but I don't know what triggers it. I have not tried 2022.5 yet.
Mac Mini 2018 i7 Catalina
~Will |
I have the same problem for years…
Although I'm using keyboard focus for groups only. It's annoying!
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6 http://www.4tune.at |
Still happening to me on 2022.5. Might roll back to 2021.7 but i've gotten used to the global search, and custom key commands, so I'd love to figure it out. It happened to me again yesterday and I saved a log, and I also noticed that when the issue happened, the keyboard shortcuts for toggling keyboard focus didn't work.
-Evan |
Edit Window Losing Keyboard Focus With Midi Editor On | lesbrunn | Pro Tools 12 | 19 | 07-07-2017 07:16 PM |
PT Keyboard Focus | BenZenium | Pro Tools 12 | 2 | 02-14-2017 07:30 AM |
Keyboard focus | nairoelo | Pro Tools 11 | 2 | 10-28-2016 10:06 AM |
Losing command focus after dialogue window | real_eyes | Pro Tools 11 | 2 | 09-04-2015 11:59 AM |
PT9 Keyboard Focus | hwill2008 | macOS | 4 | 11-30-2011 11:54 AM |
