Avid Ethernet Support (x64) could not be found.
Trying to reinstall Pro tools 11.2 and 11.1.2 but installer cant complete, I just get this..
The files for installation requirement Avid Ethernet Support (x64) could not be found. The installation will now stop. This is probably due to a failed, or canceled download. Initially I couldnt connect with Mbox which is why I reinstalled. The only thing Ive done differently recently is try to install Structure on my F drive..that failed so now Im stuck with this new problem.
Intel 6 Core i7-4930K CPU @ 3.40GHz 32GB DIMM DDR3 G.Skill Samsung SSD 840 EVO WD Black SATA 7200 ASUS SABERTOOTH X79 Windows 7 Ultimate 64 Mbox3 Pro Firewire 400 ProTools 10.3.8 ProTools 11.3.1 https://soundcloud.com/matthewcrowe |
Re: Avid Ethernet Support (x64) could not be found.
Have you uninstalled your old copy first?
I would uninstall your old copy, reboot, then try the install again. If that doesn't work, then maybe the installer is corrupt. In that case, try re-downloading the installer and try again. |
I figured it out, the download wasn't extracted properly.
Avid Ethernet Support(x64) missing???? | 6505smith | Windows | 2 | 08-28-2013 12:34 PM |
Avid support code not found | hijinxbassist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-02-2012 05:59 AM |
Dear Avid customer support! Would you please answer my both avid support cases | Ale | Pro Tools HDX & HD Native Systems (Mac) | 0 | 11-24-2011 01:56 PM |
Ethernet card not found - Win XP | Fabrizio | Pro Tools TDM Systems (Win) | 4 | 03-31-2009 03:29 AM |
Why no ethernet support for my controler? | drogan88 | Pro Tools M-Powered (Win) | 3 | 05-13-2005 11:05 AM |
