Re: Frequent crashes when working in the MIDI Editor window
did you figure this out? if so please post your solution so others can use your knowledge...
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
Quick update:
I did hear back from Avid support. They have me run a few more tests to try and isolate the problem. Said something about there being an "access violation" somewhere, but they're not sure where. I did test out a bunch of different scenarios in the meantime (new session, old session, importing various midi files, starting from scratch, and so on) and got crashes over and over again.
Vincent L. Pratte www.vincentlpratte.com ----- Pro Tools 2021.10/12 / Mac Mini (2018) CPU 3.2 GHz i7 RAM 32 Gb (DDR4) / OS 11.6.4 |
Another update :
So I kept on testing different scenarios trying to narrow down what the cause could be for all those crashes.
Here's a quick video of the last crash, in case people are wondering what exactly I'm doing in the MIDI editor: video of latest crash I was able to reproduce the crashes on my Macbook M1 running Monterey (this is after PT was certified compatible with Monterey). Though I didn't get crashes per se, but rather PT would hang forever with a spinning wheel. Tech support seems to have given up on me. Probably not enough people working with MIDI the way I do for this to be an issue worth really looking into... I've had to switch to a different DAW just to finish some projects recently, which is a shame, I don't want to give up on PT just yet.
I would at least run some tests on your RAM in case you have a bad stick. My old Windows pc was crashing all the time in Pro Tools and it ended up being a bad stick of memory.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
When I ran the test on my Macbook Pro, I used the internal soundcard. I'll run another test on my main rig with the 2i2 disconnected, thanks for the suggestion. Doesn't quite explain why my issues only occur in the MIDI Editor though. I'll look into the RAM, but if that were the case that there was a bad stick, wouldn't that affect other DAWs I'm working with too? I recreated my entire template in Digital Performer (took forever ) and had no issues there whatsoever. EDIT: Just ran a quick test with the 2i2 disconnected and PT engine set to internal soundcard. Same result (crash). Also ran diagnostics on the hardware and it didn't find any issues with the RAM.
Vincent L. Pratte www.vincentlpratte.com ----- Pro Tools 2021.10/12 / Mac Mini (2018) CPU 3.2 GHz i7 RAM 32 Gb (DDR4) / OS 11.6.4 Last edited by vincentlpratte; 04-20-2022 at 01:44 PM. |
I have the same incredible situation.
Thirdy parts? But we must work with thirdy parts like Vienna Ensemble Pro, Kontakt ecc. ecc. If you are in the businness you must use thirdy parts quality elements. I did a file, ten miserable unconnected MIDI tracks and after editing some CC or notes PT crashes. I have contacted support, they told me to uninstall PT, create a new account and install ProTools there. So in the nightime, instead of sleeping, I created the new basic installation of ProTools, create a new file with 10 MIDI unconnected tracks but they crashes again and again. Then AVID support ask me the crash log files. I'm waiting. By the way who has all this time to enjoy himself with this kind of things? I'm not paid for that. Some days ago I went in a studio and because of this crashes I used Reaper to save my work. Customers cares only about deadlines, quality and speed. |
I’ve seen this before. I run a template with hundreds of deactivated INSTRUMENT tracks. But when I start having a lot of “live” ones, it starts having problems and crashes if I’m trying to do too much too fast, or doing anything during a Save or Auto-Backup. I don’t have a specific rhyme or reason to it tho, aside from PT maybe not being able to handle a load of operations while saving. 2021.12. Mojave
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
Ive run into the same issues. I even get pops when editing midi notes. I’m going to replace my ram to see if this helps
I have no clue what to suggest BUT I can say on my machine OS and PT 2021.12 (below) I am not getting any of these issues ?????????????????
Now admittedly I do not run big sessions. Usually 6 to 8 audio tracks and 1 to 5 instrument tracks... BUT I just spent several hours editing a session of mine with:: 3 instruments , two Falcon tracks the Model D piano and a Celeste and a Slate Drum track ---with no glitch or problem at all
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Hi, I’ve been having a similar problem. Did you ever resolve this?
Thanks |
MIDI Editor window responsiveness when MIDI CC automation data is displayed | wmsack | Windows | 2 | 08-11-2022 08:29 AM |
MIDI Editor window responsiveness when MIDI CC automation data is displayed | wmsack | Pro Tools | 2 | 11-22-2021 11:47 AM |
Showing MIDI Notes Being Played While in MIDI Editor Window? | ianbee | Pro Tools 10 | 12 | 10-12-2016 06:39 AM |
Midi Editor window | bobbyrichards | Pro Tools 10 | 1 | 03-07-2013 02:29 PM |
Can you trim MIDI regions from inside the MIDI editor window? | emspace | Pro Tools M-Powered (Mac) | 0 | 07-06-2010 12:13 PM |
