ProTools 8.0 won't function on a brand new Mac
Friends,
I really, really need your help! I just bought a brand new Mac: Mac OS X --- Version 10.5.6 Processor 2.93 GHz Quad-Core Intel Xeon 6 GB 1066 MHz DDR3 I have numerous internal terabyte drives, in addition to my system drive (I know they say NOT to save ProTools files on the system drive). (1) I open up my ProTools LE 8.0, and I try to play back a simple little .wav (2) It says, "ERROR --- CPU is holding back USB audio. Remove some plug-ins, delete some tracks, or increase the 'H/W Buffer Size' in the Playback Engine dialog. (-9136)" (3) I don't understand this at all. The reason I bought this super-powerful Mac was to AVOID these type of issues! (4) Just like always, I go into the Playback Engine and try every possible combination allowed by the Playback Engine. (5) The same error continues to happen. (6) I restart my computer. Same errors, no matter the configuration of the Playback Engine. (7) I try saving files on various different drives, including my GLYPH. Same errors. (8) Remember: there is only ONE TRACK !!! No plugins whatsoever. Can anyone help me? THANKS SO MUCH IF YOU CAN HELP!!! [email protected] |
Re: ProTools 8.0 won't function on a brand new Mac
Perhaps tell us what PT interface you are using?
Have you upgraded to Snow Leo compatible version of PT?
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
digi tech support doesn't work on fridays
you have to waiti til monday wish i could take 3 days off like that
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I've moved this to the correct forum. And, as Mundoz asks - which LE hardware are you using...? |
I am using a Digidesign Mbox.
Re: ProTools 8.0 won't function on brand new Mac
I would post this in the LE/Mac forum and also include the interface you're running as well as the type of external hard drive.
moved to correct forum
How many processors are dedicated to Pro Tools?
What is the sample size and bit rate of the session? Was the recording imported or made on this same system?
Mac Pro - 8 core 2.8 GHz - 6GB RAM - 10.5.8 Pro Tools LE 8.0 - MPT2 - 003R |
Hello, BlueThursday.
Not sure how many processors are dedicated to ProTools or how to affect this. Can you help? With regard to the other question, ProTools won't play ANY .wav file at all, no matter what sample size or bit rate. THANKS if you can help! |
ProTools Freezes Brand New Imac | alecmcmahon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-11-2007 12:52 AM |
Protools is crashing my brand new mac on entry... | mcmattp | Pro Tools TDM Systems (Mac) | 3 | 08-12-2006 08:36 PM |
ProTools 6.9 brand new COMMAND KEY glitch | the barn studios | Pro Tools TDM Systems (Mac) | 3 | 06-28-2005 09:50 AM |
HELP! Protools makes brand new powerbook restart! | radiospark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-14-2004 10:25 PM |
brand new G4/001 - ProTools le freezes | lsr1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-13-2000 03:40 AM |
