Group i/o Select
I've dug my way through the manual and can't seem to find an answer.
Is there a way to change the output of a highlighted selection of tracks. Say select drums to output 1 and 2 Bass output 3 and 4 Guitars output 5 and 6 Vocals output 7 and 8? Without having to change each individual tracks output. Thanks and sorry if it's been discussed before. |
Re: Group i/o Select
Hold shift and option, and all selected tracks will do the same thing..
Hold Control, option, command, and the outputs will cascade upwards through the available outputs. Cheers Dave
2.66 Ghz Quad-Core Intel Xeon, OS 10.6.3 HD3 Accel, Control 24, PT 8.1 cs1 |
Thanks!!! I knew the second command already.
Select in Region bin won't select region in edit window? | innerbooty | Pro Tools TDM Systems (Mac) | 3 | 03-24-2013 11:04 AM |
1 track in group isn't responding with group! | gregwor | macOS | 7 | 01-25-2011 07:22 PM |
Select regions in group | kje | Pro Tools TDM Systems (Mac) | 5 | 11-13-2010 04:21 PM |
select regions in group | basslik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-05-2009 06:35 PM |
Group Persists for Resizing Even When Group Turned Off. | holden | Pro Tools TDM Systems (Mac) | 3 | 06-24-2008 03:31 PM |
