Structure Default Patch settings
Please forgive me, I've been away from Structure for a LONG time. I'm having a play with it again, and can't find out if there's a way to do this:
I want to create patches via drag & drop from the PT Edit Window, with all my favorite settings already mapped to my controllers. Things like Attack & Release, and so on. The only way I can find to do this now is to 1st save a patch with everything mapped then, -load it -click to the editor -select the "existing sample" in the patch -drop my new sample onto the old one -map the sample in the dialog box That's 5 steps to do what I'd like to do with just dragging & dropping 1 sample. This is a step (for Sound Design) that I'd be doing dozens, or perhaps hundreds of times a day. So you can see that the workflow needs some work, unless there's a way to set this up as a default already and I just haven't found it yet. |
Can I make a Structure patch with Structure Free? | weezerboy | Virtual Instruments | 11 | 03-28-2011 12:04 PM |
Structure Assigning patch with the Triangles next to patch name? | VanAmp | Virtual Instruments | 1 | 09-06-2008 09:45 PM |
Default patch settings? Drag & Drop replace sample? | Farmer Dave | Virtual Instruments | 8 | 02-28-2008 06:22 PM |
Default Midi Patch Names Problems: Need Help | citi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-12-2006 01:04 AM |
Why does my MIDI channel always default back to patch # 10? | Fucius | General Discussion | 1 | 09-29-2001 09:24 PM |
