select regions in group
i have my drum kit grouped but i need to trim one of the regions, when i go to trim just one region it automatically highlights the whole group for editing, do i have to take that one track out of the group just for a quick edit? thank you *GOOD DAY*
Re: select regions in group
Just deactivate the group in the bottom left and then reactivate.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
when I'm doing group editing I use the quick keys to activate de activate groups- SHIFT+APPLE G. This really helps for speed and workflow.
Cheers Jim |
While in grouped mode:
Try holding the Ctrl key while you trim. Holding Ctrl should allow you to change the parameter of just one of the grouped tracks (without deactivating the group). This works for moving just one fader of a group in the mix window. Patrick |
man you guys are awesome, that's a understatement too. thank a million, also i will post my first ever recording and hopefully get some pro feedback from you cats, thanks
ok i understand how that works in the mix window, but i the edit window to trim one track while holding the control key doesn't work? do i have to have a certain tool selected?
You're right, it doesn't work in the edit window; only in the mix window. Looks like the Shift+apple+G is your best bet.
Key command to de-select regions previous and next regions? | jkuehlin | Pro Tools 10 | 1 | 08-03-2013 06:52 AM |
Select regions in group | kje | Pro Tools TDM Systems (Mac) | 5 | 11-13-2010 04:21 PM |
Group i/o Select | Keith Moore | Pro Tools TDM Systems (Mac) | 2 | 03-30-2009 11:25 AM |
"Select Unused Regions" selects USED regions. Please help.. | pukeuv | Pro Tools TDM Systems (Mac) | 9 | 04-26-2007 02:04 PM |
PT LE how do I select ALL audio regions??????????? | Johnny916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-21-2004 08:39 AM |
