Old 11-06-2019, 02:36 PM
Mark Frith Mark Frith is offline
Default Digidesign 96io with Avid Omni?
I'm pretty sure it's possible to hang a digi192 interface on the legacy port of the avid omni, but is this also the case with the 96io? I don't see why not but I need to know for certain...is anyone working this setup?
sorry if the answer is already here somewhere - I can't find it.
Thanks M
Old 11-06-2019, 03:06 PM
Default Re: Digidesign 96io with Avid Omni?
Actually maybe it needs to go on the 2nd port of the hdx card..?
Old 11-06-2019, 09:11 PM
You can connect to 2nd digilink of the card, or you can daisy-chain it with the first one. The only restriction is you cannot have more than one OMNI but other HD interfaces can be mixed as you wish.
"LEGACY" port is for MIX era black interfaces.
Old 11-06-2019, 09:54 PM
Awesome, thanks. M
Old 11-06-2019, 11:09 PM
No problem.
Have to add that the Legacy Port might not work on current Avid-branded PT software any longer, but at least it did with DigiDesign (pre-9) versions. In that case, when you selected Legacy port from hardware setup, the wordclock i/o (normally standard 1x clock) begins to feed 256x superclock needed for MIX interfaces. And obviously you are limited to 48k max.
Old 07-20-2020, 09:44 AM
sweetbabysims sweetbabysims is offline
Hi All!
With the OMNI and Digidesign 96io set up...
- Confirming the 96 i/o is connected to the expansion port on the OMNI?
- Is a Mini Digi-link to Digi-link adapter also required to connect the 96 i/o?
- Is a BNC connection required for Loop Sync?
- Possible to clock the whole system off the 96 i/o?
Thanks so much in advance! Apologies if this was answered. I can't find these specific questions.
Old 07-20-2020, 09:46 AM
DigiDesign interfaces have the old connector so yes adapter is needed. And tes you need to set up loop sync any time you have more than one interface connected
Old 07-20-2020, 09:49 AM
Thanks for the speedy reply!
Possible to clock the system to Digi 96 once set up?
Any known issues with PT 2020.x?
Old 07-20-2020, 09:50 AM
Why would you want to use the 96 clock that is not as good as OMNI?
Old 07-20-2020, 09:51 AM
Set up your OMNI as clock master, after that 96 replicates that clock and yes you can use the 96 clock outputs just like OMNI clock putputs
Digidesign 96io Interface dexter808 Buy & Sell 0 03-24-2016 01:28 PM
Digidesign 96io Loudnoize Ent. Buy & Sell 4 03-13-2015 01:31 AM
FS: Digidesign 96io TXDigi Buy & Sell 0 01-29-2014 09:06 AM
FS: Pro Tools HD3 PCIe + Digidesign 96io Mihael Hercog Buy & Sell 1 12-21-2013 09:44 PM
Digidesign 96IO Connections jerberson12 Pro Tools TDM Systems (Win) 0 07-10-2012 02:36 PM
